Question about Samsung LNT5265F 52 in. LCD HDTV
Slow start pink spots on black backround - Samsung LNT5265F 52 in. LCD HDTV
  • 4 Answers
Write down your serial # (found on the back or on the side) and your model # and call 800-Samsung. The issue has to do with the capacitors and if your TV was manufactured between Dec 2007 and May 2008 they will send a repairman out to repair for free (one time only). I just called and they are sending someone out to repair mine. Apparently there are tons of people experience the same problem.
Posted on Aug 11, 2010
Pink spot on lcd tv (about 5 yrs old) started yesterday
It is very likely that your tv is experiencing a light engine failure, $$$ very expensive repair! Are the pink spots confined to one area?..
Nov 27, 2010 | Panasonic PT-52LCX65 44" HDTV
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
May 03, 2010 | HP Vs17 17" LCD Flat Panel Monitor
While i am playing Mariocart a black backround
almost certain it is a scratched disc if you can play up to a certain point
Feb 25, 2010 | Video Game Consoles & Games
My TFT LCD Monitor, serial #MT-NI-DYLM2286 produces a light pink backround, but prints clear. Is there some way to return the monitor to a clear white backround?
rjmusvi, Sometimes the VGA connector at the rear of the PC needs to have it RESEATED 4-8 times to see if it returns the screen to NORMAL colors being displayed on the LCD panel!!! Do this with the POWER OFF to both PC and LCD monitor!!! Also check to see if any of the pins in the monitor to pc plug are bent or pushed down into the connector body. 12fixlouie on fixya
Dec 03, 2009 | Soyo Computers & Internet
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Settings/backround colour
Heres how you do it
Press Menu
Settings
Display and light settings
Display settings
Main menu style
Click on black
Save
Go back to main menu and see the change
Hope this works
Plz let me know
JonnieC
Feb 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Computer slow
A slow pc could mean alot of things. Virus's, spyware, too many programs running in the backround, and tons of old files,and cookies that need to be cleaned out often.
First download AFT cleaner and get rid of all the temp, files.
http://www.snapfiles.com/reviews/atf-cleaner/atfcleaner.html
after you clean all cookies and temp. files, go here and do a full free scan. If it finds anything, it will clean it. It's safe and free.
http://housecall.trendmicro.com/
If you have McAfee or Norton it will **** the life out of your computer unless you have at least a 1or 2Gb of ram.
The free virus programs are very good.
http://www.snapfiles.com/reviews/avast_Home_Edition/avast.html
or http://www.free-av.com/en/download/1/download_avira_antivir_personal__free_antivirus.html
spyware program
http://www.download.com/Spybot-Search-Destroy/3000-8022_4-10122137.html
After that, you may have too many programs running in the backround which will also slow you down.
In XP go to run, in Vista , go to start, type " msconfig " to get to startup. General tab, click on selective startup.
On the startup tab uncheck anything you don't want running in the backround. Hit apply and reboot.
Everytime a program gets installed, by default, it's in startup to run whenever pc is on, even if you don't see or need it all the time. By unchecking music players, printer's and even update's they will still work when you need them. Update's for things like Roxio and quicktime are not needed.There is a check for update's to every program.
Jul 06, 2008 | Computers & Internet
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Samsung LNT5265F 52 in. LCD HDTV Logo
374 people viewed this question
Jerry Greenberg
Jerry Greenberg
