Question about Jenn-Air JCB2388G Side by Side Refrigerator
Probleme if haven the card control
Did you haven the control card
What is a easy way to delete photos
The best way to delete all the photos on a memory card is to format the memory card. This is not only easier than deleting individual photos but also prevents future problems from fragmentation. FixYa is full of people asking how to recover photos from memory cards that haven't been formatted regularly.
Feb 18, 2012 | Samsung Cameras
When ever i turn my camera on with the sd card in it reads card error. ive tryed cleaning for dust making sure the sd card wasnt locked but nothings working to help me fix the "card error"
Your card may be full or damaged.
Is the card compatible with your camera - most cameras will work only with specific cards.
Does the camera work with another card? If you haven't tried that I would suggest you do so.
If you get the same message with another normal card then the problem may be with your camera.
Aug 02, 2011 | FUJIFILM A220 Digital Camera
My phone seems to be continually trying to connect to a PC which I haven't asked it to do and I can't receive or send any messages while it is doing this. How do I get the phone out of this loop
what is the brand of your phone?if nokia, the easiest solution of that problem is to format your phone but first you have to back up your important files. if you have memory card just save it in there and remove the memory card before you start the procedure so that memory card will not be affected. how to format? just type *#7370# and it will ask your security code. the default code is 12345 if you haven't change it. if you change your security code enter it start format your phone.
i hope it will help you
Jul 24, 2011 | Cell Phones
A few problems with my dell 9150. 1 Windows boots up but screen shows garbled then turns black and monitor into power save mode. I tried a complete system recovery, still the same.
I would try starting up in VGA mode (tap F8 at the splash screen and choose VGA mode from the menu)
VGA mode will load very few drivers and a generic video driver into Windows. From there you may be able to go to a website and download the latest (or even rolled back) drivers. Or you can uninstall and reinstall the drivers from the Device Manager (in the control panel)
This article from microsoft provides a little more detailed information:
http://support.microsoft.com/kb/268852
May 20, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My sapphire X1950 GT has worked for 4 years, and it may just be wearing out, but all of a sudden it doesn't work at all. If it is installed into my BUS port then the computer still functions, but nothing...
Your card is actually archived and now only has limited driver support.
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista64.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
It sound like it has trouble readfing or is having resolution problems but, if you haven't updated driver recently, that could be the problem. There is no support for Windows 7. The link above is the only driver with Catalyst Control for your card. You may want to consider a new one.
Apr 25, 2011 | Sapphire X1950 GT 256MB GDDR3 PCI-Express...
Asus k52jc graphic card problems when i play pro evolation soccer 2011
hi this problem because your card graphique it s not power to let you play this game,or because you haven a enough memory.
Feb 23, 2011 | ASUS K52jc-b1 15.6" Notebook - Core I5...
I am haven problems getting the right memeory card for my digital camra 3.3.1.5.
note... this sounds like the classic confusion between the SD and the SDHD card.
Note whatever you are using now that is not working and get the other one!
Oct 04, 2010 | Cameras
Sound problems with Windows XP 2002
The very first thing we should do is to check whether the sound card is installed in your system.
To check open device manager. Here are steps to open device manager
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Double Click on Sound, video and game controller.
If you do not see Sound and audio controllers, then you have to install it,
Installation of Sound Card.
  • Select the Multimedia Controller or Sound and Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Browse Your Driver from the Hard Disk and click on next.
  • You can also install the drivers from CD.
Driver will be installed if the problem is still exist. Replace the sound card or have a local tech take a look at the sound card.
May 17, 2010 | Computers & Internet
Sabrent USB 2.0 5-Port PCI problem - ''Pri Master HDD Error''
If you already haven´t installed the driver, I would recommend downloading it from http://www.sabrent.com/drivers/UF6.zip and only then, after a successful install, connect the hardware.
Mar 30, 2010 | Computers & Internet
Blue Haven 6100 reset problem
you cant reset mean new star you must enternew settings
Jul 06, 2009 | Jandy AQUALINK RS TELELINK KIT
Jenn-Air JCB2388G Side by Side Refrigerator Logo
35 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
