Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Engaging the blades / PTO
JD GT 262 what lever / button do I press to engage the deck? Thank you.
    President:
  • 1,627 Answers
There is either a yellow toggle switch or a yellow knob type switch on the dash panel that will engage your deck unless some of the safety switches are stopping it from working due to an adjustment problem or a defective switch,let me know if you need more help.
Posted on Jul 15, 2010
My jd la135 dies when mower deck is engaged it is not electric pto
check for obstruction
be sure blades move freely
engine off spin blades by hand
Jun 15, 2016 | Garden
A PTO that is engaged constantly,
On that type PTO engagement there is slack in the belt that disengages the deck, in some case there is a arm with a idler pulley that swings against the belt to tighten it and engages the deck , in other cases like older MTD:s the deck swung backwards as it was let down and tightened the belt and was lifted to turn it off. Most of the decks had a brake of some kind on the deck pulleys to stop freewheeling of the blades when disengaged .
May 26, 2016 | Garden
Lawnflite 703 cuts out when I try to engage blades with pto lever
are the blades stuck on something or seized up , ck to see if they are not bent and stuck on something like the deck
Mar 07, 2015 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
JD Model LX178, 1996 Model year. Engine runs but mower deck will not engage? (worked ok yesterday)
It could be a few things:
1. Check the belt that drives the blades; it could be broken or slipping.
2. Make sure the PTO Switch/Lever is working properly. The cable could be broken, or the spring that sometimes help to engage the blade could be broken.
3. There may also be a large stick lodged in the belt that drives the blades.
Good Luck!
Jim
Jul 29, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Were does the cable hook on the deck that engages the blades
you have to give more info
If its a manual engage the lever tightens up the belt by sliding a pully against the belt
If its an electric pto it has an engadge button and that powers up the eltric pto wich inturn runs the belt
Jul 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
289 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
