Question about Midland LXT320 (14 Channels) 2-Way Radio
Why is one of my midland lxt320 2-Way Radio suddenly not turning on
Midland 75-822 frozen on channel 19.
radio is out of lock .Replace the I C and it should unlock or you could try to do it your self but you would still have to replace the I C .
Oct 12, 2016 | Midland Radio Midland 75-822 Handheld...
Wont turn on
did you try plugging it in. if its AC/DC try the other one to see if the switch is in the wrong position . May have a blown fuse also .
Dec 09, 2013 | Midland Radio Midland Gxt 1000 Vp4 Radio...
I have a set of two Midland LXT420, made in China. One of them have suddenly stop working, doesn't turn on. And about a month after, the second one went OFF. Both batteries are charging till 5.9 yo 6.1...
It is likely a fuse inside the radio that is open, or possibly some poor solder connections. I would call whoever you purchased them from and have them take a look.
Mar 18, 2017 | Midland LXT410 (14 Channels) 2-Way Radio
Midland cb radio. when i turn on my wipers i get a noise over the cb radio
This is usually caused from a poor ground. Try to reground the radio to a better location and it should fix it.
Jan 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
Midland weather radio model-100 I need the
Click this link- WR-100 Weather/RDS Radio Manual. I got this link from the Manual section of Midland WR-100 Weather/RDS Radio web page on this website.
Jun 30, 2010 | Midland WR-100 Weather/RDS Radio
77-099 CB Radio: my midland just wont turn on anymore. is it a fuse...
hello you will not find an internal fuse though theres what we call a dummy or/reversed diode this is located at the rear of the radio beneath the top cover ,also check fuse along the radio line from battery to radio should be around 2-5amp fuse ,hope this helps
May 16, 2010 | Midland 77-099 CB Radio
Midland WR-100 Weather Radio Troubleshooting
With this radio receiver you have to set the county or counties code for the alert system to work. This encoded tones turn the radio to receive the alert signals.
Feb 09, 2010 | Midland WR-100 Weather/RDS Radio
Midland WR 100B Weather Radio
Try setting the S.A.M.E. code setting from Multiple or Single to ANY.
Feb 04, 2008 | Midland WR-100 Weather/RDS Radio
Midland LXT320 (14 Channels) 2-Way Radio Logo
55 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
