Question about GPS
No reset button
Tomtom ONE XL
  • 1 more comment
  • Anonymous Jun 20, 2008
    My Zumo is locked up. How do I reset it?
  • Anonymous Jun 29, 2008
    iam not receiving any signal
  • Anonymous Apr 06, 2009
    ich habe an meinem tomtom 300 eine karte vom tomtom rider probiert.
    funktioniert aber nicht.habe die originalkarte eingesteckt,nun funktioniert mein gerät nicht mehr.
The problem I had started with a bad car adapter, the battery of my Garmin ZUmo was completely depleted. It then went into a shut-off state which I could not reset. My motorcycle dealer had showed me how to reset it. Connect your Garmin with the A/C adapter, push on the right lower edge of your screen, and simultaniously push the power on/off button. If I would push this combination again I would set it back to factory defaults. Strangly enough I could not find this option in the manual.
Posted on Apr 29, 2008
    Problem Solver:
  • 7 Answers
Its NOT a generic problem for ALL gps devices as most TT devices have a RESET button as do quite a few others. Usually RTM tells you where it is. The XL and XLS both have them near the card slot.
Failing RTM the RTFM works.
Posted on Apr 02, 2009
Not picking up gps
Try performing a reset.
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on.
You may also want to contact TomTom Customer Support for assistance.
http://us.support.tomtom.com/app/answers/detail/a_id/6964
Nov 01, 2011 | Tomtom One XL GPS Receiver
Hi , My tom tom has been great, all of a sudden it registers zero sats but when i go into sats configure it says that it is reading them by the individual signal levels but back on the map screen it still...
Try resetting your TomTom.
push the reset button. The reset button is next to the memory card slot on the
I have attached the link to the manual which shows a picture on how to do it.
Thanks for using FixYa
http://download.tomtom.com/open/manuals/onexl/refman/ONE_XL_US.pdf
May 26, 2011 | Tomtom One XL GPS Receiver
How can I make my tomtom one XL GPS turn on
Your TomTom may have to be reset. According to the manual:
Remember, after a reset, your TomTom MAY take up to 20 seconds to start when using it for the first time.
Hope this helps.
Apr 29, 2010 | Tomtom ONE GPS Receiver
Where is the reset button on the Tomtom xl340s
The TomTom XL 340-S uses the power button as a reset. With the unit turned off, hold down the power button for approximately 15 seconds, until the TomTom turns on. As soon as the unit turns on, release the power button. The unit is now reset.
Nov 21, 2009 | Tomtom XL 340S Car GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
May 12, 2009 | Tomtom GO 720 GPS Receiver
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
May 11, 2009 | Tomtom ONE XL GPS
Reset
Tap "Reset factory settings" button to restore the factory settings to your TomTom XL. All your settings, including Favourites, your Home location, warnings for POIs and any Itineraries you have created are deleted.
Tap "Set Clock" button to select the type of clock that is shown and set the time.
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
20/Apr/09
Apr 02, 2009 | Tomtom XL 330 Car GPS Receiver
GPS Logo
1,207 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
