Question about Liebherr K 4260 Refrigerator
The freezer compartment on my under counter fridge is broken can i disconnect it and still use the fridge
  • 4,059 Answers
I'm not sure about yours but on most the fridge compartment gets it's cold from the freezer so you can't run it separately.
Posted on Jul 15, 2010
Testimonial: "As I suspected. Great. Quick response. Thankyou."
We have water om the floor under the laft fronmt corner of our fridge/freezer . Model tbx 22pr
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Try to check the defroster heater this cause the problem;
Jul 30, 2008 | GE Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
REFRIG E402BRE
My fridge (E440T but I believe the E522 is similar) has EXACTLY the same symptoms and the reason was a broken fan wire in the freezer compartment (behind the rear panel). The fridge compartment works by drawing air from the freezer and blowing it into the fridge compartment. If the fan in the freezer doesn't work, then your fridge won't get cold (there is another fan in the fridge compartment so it will stay a little cold but not enough).
If you're game, I created a document for others to follow if interested at http://mail.accentis.com.au/downloads/misc/How%20I%20fixed%20my%20Fisher%20and%20Paykel%20Fridge%20Active%20Smart%20Fridge.pdf
Thanks to all postings on this site - it really helped a lot, had me some fun and saved money!
Jun 16, 2008 | Fisher and Paykel Active Smart E522B...
Amana ARB2217C Fridge
its under the light bulb assembly in the frigidare compartment
Dec 29, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Liebherr K 4260 Refrigerator Logo
139 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
