Question about Ungo SR6000 2 Way Security with Remote Start Combo System
My 2000 ford focus will not start security light always on
When battery is removed and reinstalled car will start how can i disable secuirty system, so I can start car to get it into a repair shop??
I have tryed turning it on to release it from park to put into neutral thinking I could start it that way. I could not get it to shift into neutral.
Would it be possible to remove the fuse for the security system and start it that way???
    Top Expert:
  • Buck Master
  • 83,951 Answers
You need the security system scanned with a special Ford scan tool to see what is causing this lockout
Posted on Aug 16, 2017
Ford focus 09 turn key all lights up but no start changed battery and starter motor>??
no start changed battery and starter motor ????? Did you test before replacing these Parts ? Do you know about ford smart starting systems ? (computer controlled )
008 Complex Circuit Analysis This is your stating circuit .
Feb 19, 2018 | Ford Cars & Trucks
How do I find fix my 2000 Ford focus, the dash light's won't come on and it will not start.
Check your battery and your battery posts, charge your battery if necessary, check your charging system.
Feb 10, 2016 | 2000 Ford Focus
How to change air conditioner hose in 2000 ford focus
1st thing you must do is evacuate the system. then remove to hose with the proper tools and then reinstall and recharge system to proper level.
Oct 05, 2009 | 2000 Ford Focus
How to fit a fan belt in a 2000 ford cougar
disconnect the positive terminal lead to the battery and loosen the3 bolts to the alternator remove old one and reinstall new one ...using a grow bar or prybar rest it behind the alternator upper bracket and give some tension to it causing the belt to tighten then secure bolts and reattach the + positive lead terminal ..
Sep 13, 2009 | 2000 Ford Focus
2001 Ford Focus won't start
Did you check the fuse box. The one in the engine compartment and in the dash board on the drive side.
to see if you blow a fuse.
Also is you security light flashing
Sep 08, 2009 | 2000 Ford Focus
Secuirty Light
Security system has been triped. Try using remote or key in the door. Lock door, then unlock. Should reset system. Let us know if that works.
Jul 29, 2009 | 1995 Jeep Grand Cherokee
Ford focus-99 abs module
if the ABS system is functional u will have no ABS warning light showing in the dash except when u first turn the key on, that is a prove out to show the indicator light is working. If the ABS has a problem of any kind the light will always stay on when driving and the system will be disabled..
Jan 22, 2009 | 2000 Ford Focus
2000 ford focus automatic clicks no start
Good day;
Have you have this problem before? If you had the battery change a month ago the first place that I would look at is to make sure that your battery cables are on proper. I would remove the cables from the battery and put them back on and make sure that they are nice and tight. Let me know how you make out with this.
Cheers.
Aug 07, 2008 | 2000 Ford Focus
2000 Ford Focus
Unlock your car 1st than don start with instantly,
than charge that system for ignition than you can do easily,
Take care
May 15, 2008 | 2000 Ford Focus
Ungo SR6000 2 Way Security with Remote Start Combo System Logo
293 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
