Question about Mitsubishi VS-60719 60" Rear Projection Television
I have a wd52525 52 in widescreen dlp projector and the fan noise is outrageous and never turns off. Is this normal? If so is there a cure?
There are 4 fans one is loud more then likely the ballast fan
Posted on Oct 28, 2008
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Noise probably from fan
Amost certainly a failing bearing on a fan motor, or, if you are really unlucky, the colour wheel drive motor. Most probable is a fan fault. The only real way to isolate it is to test each fan in turn until the faulty one is found. If you are lucky, the faulty fan may feel stiff or rough when you rotate the blades gently by hand. If it's not a faulty fan, you are in for a rather expensive repair....
The bearing cannot be repaired - the faulty fan must be replaced
Mar 27, 2014 | InFocus X3 DLP Projector1600 ANSI Lumens,...
My PDJ6553w projector turns on, giving me 2 min picture, turns off and the fans goes crazy
sony lcd turns on, giving me signal and picture in 2 minutes, then suddenly turns off and the fans goes crazy. what can I do to prevent this? I have tried to reset the projector and switched the powermode to normal, but this didn't help.
Feb 16, 2013 | Viewsonic Corporation Viewsonic PJD6553w...
Fan makes a loud noise i tap on the top then it goes away . Or if I blow in to the vents it goes away then comes back later? let me know
Sounds like filter is clogged or dirty. Take a vac cleaner to the vents. If that doesn't cure it, then disassemble and clean thoroughly.
Jan 07, 2011 | Optoma HD20 DLP Projector
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
High pitch noise from the projector and is not from the fans
it's the colorwheel. if you have an infocus x1a, it is a dlp projector and has a colorwheel and dmd chip instead of 3 lcd panels. the colorwheel spins to allow the lamp to stike. it should make a slight high-pitched squeal. if it's too loud, the motor is shot and needs replacing.
Aug 13, 2009 | InFocus X1A DLP Slide Projector
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
EP719 Projector is "Buzzing"
Could be something touching the color wheel
Dec 19, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Mitsubishi VS-60719 60" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
