Question about Danby DCD5505W Electric Dryer
Start Button on Danby 5505W Dryer -- has stopped working
"Start" button won't work -- you press it and nothing happens. It's plugged in; the circuit is working. The "on/off" button works but the "start" won't get the dryer going.
What should I do? Do I need a repair person? Is this a common problem? Or is there a commonly known part/problem and I just have to follow up?
  • 11,896 Answers
This is not to common unless the door switch is faulty which is common and could cause the dryer not to start. The switch may look fine but could be faulty.
If you had access to an ohmmeter you could test the start button and the door switch. The start switch could be faulty, but testing would have to be done to tell for sure if that was the problem.
You can try and unplug the machine for 10 minutes and plug it back in and see if it resets the machine.
If it does not reset, then testing should be done to the start button and the door switch.
There is also a thermal fuse which could pop if there was a short in the machine. I don't believe you would have any power though. You said your timer works, so that is why I am assuming start button or door switch is likely bad.
Posted on Jul 15, 2010
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
Jun 29, 2014 | Whirlpool Washing Machines
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Danby DCD5505W Electric Dryer Logo
43 people viewed this question
Top Danby Dryers Experts
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Jorge Rendon
Jorge Rendon
Are you a Danby Dryer Expert? Answer questions, earn points and help others
