Question about Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg
The print for the reading is dark and the lines are all over the place. Mac1200 Thanks, Draya
  • 71 Answers
If the ecg waveforms are all over the place you are probally recieving electrical interferance. If that happens when nobody is connected try adjusting the filters and see if it makes a diffrence. If it does not make a diffrence it might be the patient cable or leads.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Posted on Jul 18, 2010
Testimonial: "Thanks for your help. We are working to see if this fixes it. Andrea"
    Problem Solver:
  • 5 Answers
Make sure the patient was prepped correctly and that all of the electrodes are clean. Don't lean the main trunk cable across a iv pump either, that can cause interference. Make sure the electrodes are not dried out. Make sure the clips aren't broken. Double check all the connections. Make sure tthe paper is the correct type.
Posted on Nov 11, 2010
I can't read a code bar printed with datamax a4212
try adjusting your darkness settings. if too dark wont read and also if too light wont read. also try a printhead test to make sure no elements are burnt out.
Aug 13, 2017 | Computers & Internet
My printer is reading check alignment, is it because my color cartridge is out of ink?
No, that's not what it means.
If printer heads are not aligned, CMYK colors (Cyan, Magenta, Yellow and blacK - the usual colours in a printer) will not print in the correct place.
Assume a dark grey dot is to be printed. For this C, M and Y colored dots have to be placed exactly on the same spot. But if heads are not aligned, the three color dots will not be exactly in the same place. Therefore you will see Cyan, magenta and Yellow dots adjacent to each other instead of one dark grey dot.
It is always a good idea to align the print heads every time a new cartridge is installed.
Sep 23, 2011 | Lexmark X3650 Printer
How can i clean my printer ? difficult to read all the lines.. tops of some of the lettering is gone or cannot read? some of the lines r clear and then the next lines r faded or letting is not dark enough...
The print heads are all gunked up with extra dried ink. Go to start, to the control panel next, to the printer, right click on your mouse and the preferences for the printer should come up and MAYBE it will allow you to clean the print heads. Not all canon's have this ability.
Aug 22, 2010 | Canon Office Equipment & Supplies
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
We have a GE MAC1200 EKG that will only print once. The unit gets stuck (will not print - just continues to analyze) when a 2nd ekg is attempted to be printed. If the the unit is unplugged, then the unit...
The battery is weak. Disconnect the AC, battery,& then replace the memory battery. Reconnect the power battery & AC. Next is a pain in the rear, reprogram the unit; date, ID, setup, ect.
Apr 19, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
Schiller machine is not printing
If the unit print lightly or not printing anything at all?
The most common causes for not printing ECGs is one of those:
1- Too little heat on the stylus
2- Insufficient stylus pressure on the paper
Solutions:
1- Using an insulated probe, such as a screwdriver, gently press the stylus onto the paper.
2- If a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
Jun 19, 2009 | RTO Schiller CARDIOVIT AT-1...
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
Screen goes dark....won't print
driver device had to be downloaded again. We have a lot of afternoon thunderstorms in FL, so maybe something happened to driver during a storm. All ok now . thanks
Jul 24, 2008 | HP Photosmart C4180 All-In-One InkJet...
Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg Logo
154 people viewed this question
Top Ge Medical Systems Medical Experts
Electro Med Services...
Steven Clarke
Steven Clarke
ka4iup
ka4iup
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
