Question about Dryers
Hotpoint aquarius ctdoo. the door catch on my dryer is not holding the door shut. do i have to take the outer casing off to get to it to replace it? is it a fairly easy job? thaks for any advice
  • andyhale0 Apr 20, 2008
    yes the latch is attached to the door, but i need to replace the side that the latch goes into which is in the main body of the machine.
    not sure if i explained that properly! say the latch on the door is the male part of the catch and what it goes into is the female part of the catch, well i need to replace the female part. i hope this makes sense! it is a hotpoint aquarius CTD00. thanks.
  • Dryers Master
  • 19,396 Answers
You should not need to remove tho outer casing, usually the latch is screwed straight to the door, I see if I can find the replacement,
which is your model?
Posted on Apr 20, 2008
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Renew my rubber door seal on my Hotpoint aquarius CTDOO dryer around the drum area
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Nov 19, 2009 | Hotpoint NWXR473EV Dryer
Door will not close, can you buy and replace catch ?
All the parts are readily available, you probably need to replace the door catch, and door spring.
You need to seprate the 2 door halves to carry out thios repair.
Please rate my solution.
Thnaks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
How do i open the door on hotpoint WD440, latch is broken?
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
How do I repair the handle on a Hotpoint Aquarius? The handle has not come off just door catch is broken.
Remove all vvisible screws securing both parts of door, and seperate the 2 halves, be careful you do not drop the door glass.
This will enable you to see what is broken, and what needs to be replaced
Thanks.
Nov 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Door catch model CTDoo
With most dryers, you should have the ability to reverse the door so it opens the opposite way. Will this work for you, or is the tab broken off of the door?
May 23, 2009 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
104 people viewed this question
Top Dryers Experts
