Question about LG LWHD1800R Wall/Window Air Conditioner
My LWHD8000R LG windows unit just started spitting water. It's been operating just fine for quite awhile. I checked the drain pipe area and cannot see any clogging where the pipe attaches (though I have no pipe attached). I opened it up and cleaned it up as well as I could, but it will not stop. It starts building up water again spitting after running for about 15 minutes. It is tilted properly in the window. Any ideas? Can I make some sort of makeshift drain pipe for it?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
My GE window unit air conditioner isn't blowing out very cool air,and it spits what
From what you have described, it sounds like the drip pan under the unit is full of water. This can be caused by the unit not being installed properly in the window. It must have 1/4' to 1/2" downward tilt at the rear. This allows the water in the drip pan, to flow to the rear and drain away thru the drain hole. Also, the drain hole may be clogged and needs to be cleared. The drain hole can be a challenge to find sometimes, as the clog can blend in with the hole. Be patient and persistent when looking for the drain hole. A pipe cleaner can be used to clear it.
I hope this helps and thanks for choosing FixYa.
Aug 04, 2011 | Goldstar LG LW1804ER Window Air...
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
My lg a.c. unit is spitting water from the front, it has no drain holes. it is slanted backwards and the outside of the unit is totally dry
i have to, that problem many of time ,you are at a point to where you have to get the build up out of the system now because it wasnt draining, pour bleach in the system bottom base,an if you are firmiliar with drillin in some areas where it wouldnt harm any parts do so. it will help slow down the build up ,but do it towards the back of the unit,an also look for any additional drain plugs that could be undetected ,,hope i helped you out
May 14, 2010 | LG LWHD1800R Wall/Window Air Conditioner
Started making a noise, spitting water from vent
there is a drain on the pan under the cooling coil - your "blades" if you are looking in from the front cover - the opening could be stopped up going to the back of the unit - you will have to pull it out of shell to see drain line
Sep 22, 2009 | LG Electronic Window Air Conditioner
Lots of water in unit spitting all over the floor nd itd not as cold as when i got it last year
how long you last service the unit, when last you cleaned the air filter. Drain pipe might be clogged. If it has been a year it is time to service it
Aug 05, 2009 | LG Goldstar GWHD5000 wall/window Air...
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
Water spitting into room
If your AC is window unit, check the dirt underneath the unit and also check the level of your unit.
If your AC is a central unit, be sure check the drain pipe, should be toward to the outside.
Jul 08, 2008 | Haier hwr10xc6 Air Conditioner
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
146 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
