Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Would like to know what the spark plug and coil gap is for an 8 hp roto tiller.
  • 45 Answers
Not sure about plug but use the thickness of cigarette pack for coil
Posted on Sep 09, 2010
How do you test the ignition coil on 410r Ryobi tiller?
with a multimeter set on ohms resistance and in the coil wiring
you can also test by removing the plug , using a new plug connect the ht wire to the plug and ground the body of the plug onto metal of the engine-- problem
pull the cord fast and check for a spark across the plug gap
good blue spark --not a coil problem
check the air gap between the coil and the flywheel ( .005 to .010" gap) coils seldom fail and it generally the plug or switch wires that are at fault
Aug 01, 2017 | Ryobi Garden
What is the coil gap to the flywheel on a Bolens BL410 21A-121R965 tiller
A safe gap is the width of a business card
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Nov 27, 2015 | Garden
What is the spark plug gap for tiller ?
-Not. the gap has nothing to do with NO Start.
-Possibly bad coil.
Good luck
Mai
Jun 01, 2014 | Craftsman Garden
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
No spark
No spark can be several things but begin with the easiest first.
  1. Ensure the grounding wire (thin black wire) that connects to the coil is not grounded.
  2. Ensure sure the plug wire end is connected well to the plug wire, some of these clamp the wire interior cord to the metal wire end by wrapping and crimping around the plug wire.
  3. Make sure the ignition generator coil is not scrubbing against the flywheel, there should be .030 air gap between the coil and the flywheel magnets.
  4. If you are mechanically savy, remove the flywheel and inspect the breaker points, replace/adjust as needed.
May 26, 2009 | Mantis 2-Cycle Tiller
What is left to do but change the flywheel?
check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
May 17, 2009 | Mantis 2-Cycle Tiller
Spark plug gap
All these engines have a magneto ignition. The faster the mag spins the higher (better) the sparkplug voltage. So the gap is only set for the ease of starting and is not a huge part of tunning as it is on a car. Try .020 inches.
Mar 21, 2009 | Garden
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
452 people viewed this question
Top Briggs & Stratton Hammering Experts
cavs1
Thomas Merrill
Thomas Merrill
Level 1 Expert
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
