Question about Traeger Industries BBQ070 All-in-One Grill / Smoker
My traeger keeps blowing the circuit breaker I have replaced the ignitor less the 6 monthes ago is there somthing else that I should look atrex
3 Suggested Answers
SOURCE: Traeger BBQ trips circuit breaker
My two friends and I bought new Traeger's in December of 2009 and within 45 days began to trip the GFI for all 3 units. I am an electrician and did some tests to find the igniter is shorted to its case. This is a dangerous electrical condition and could result in electrocution if you bypass the GFI for a regular outlet. I have replaced the two igniters for my two friends and the problem has gone away. Mine is still failed and I am waiting for a replacement. While talking with Traeger representative, he stated they had some bad igniters installed and are replacing with a better quality unit. Good luck in your efforts
Posted on Feb 14, 2010
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the hot rod igniter (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
Posted on Apr 12, 2009
When I power on my traeger, it setws off the circuit breaker. The augher is not jammed.
The heating rod draws a lot of power. You may need to upgrade your circuit to a higher load. Alternatively, you may just have a bad circuit breaker. Have you tried plugging it into another circuit?
May 11, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Treager bbq keeps tripping breakers
I would strongly recommend you pull the control panel and inspect the fuse. Before tripping a breaker, your GFS outlet should trip, and/or blow the fuse.
If the unit is tripping circuits, then there is likely a short. Given the material draw from the hot rod, I would start with that. Putting a multi-meter on it to test voltage, should give you a basis to confirm with Treager if it's within spec. Sometimes it's simpler to replace the rod, but this can add up quickly if not the root issue.
Dec 26, 2013 | Traeger Industries Grilling
Rear tail lights not working, fuse keeps blowing
Sounds like somthing is grounded, along the way.. The easy to find it is using an inductive amp meter, and a 30 or 35 amp, self resetting, circuit breaker for diagnistics.
replace the fuse with the circuit breaker, and get it to start tripping, like pressing the brake pedal. Once it strarts cycling, follow along the wiring with the amp meter.... It will bounce wildly along the good portions of the wiring, and then give no indication AFTER or downstream of the grounded area....
Sep 05, 2010 | 1990 Dodge Spirit
Keeps blowing the breaker... only 6 months old
This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
example:
cycling too many times per hour (check manual for recommended)
low power due to weak circuit or extension cord
using generator for powering compressor (not recommended)
using low quality oil (use synthetic if hot climate)
air leaking from intank checkvalve back to pump
If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
Jul 09, 2010 | Hitachi EC89 4 Gallon Twin Stack Air...
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Furnace ignitor keeps breaking. Replaced it twice within the last month, for a total of 3 ignitors for one winter. I've been extra careful not to handle the graphite. Furnace was cleaned in the fall and...
Make sure that there is no water dripping off of the heat exchanger onto the ignitor. Reconnect all electrical connections on the circuit board and make sure the ground connections are clean. Test the polarity of the power coming in with a multimeter. Reverse polarity will fry ignitors. Make sure the furnace is on it's own breaker.
Mar 05, 2010 | Goodman Heating & Cooling
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Jan 16, 2009 | Traeger Industries BBQ070 All-in-One Grill...
Glow plug keeps burning out
coincidence, make sure your replacig the ignitor with an approppriate replacemnt,its an electricl part so no real time as to hong long they will last
Nov 13, 2008 | Kenmore Ovens
Traeger Industries BBQ070 All-in-One Grill / Smoker Logo
479 people viewed this question
Top Traeger Industries Grilling Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
