Question about Refrigerators
Hey Kapishtech--- The solution to the Hotpoint fridge problem, water in the bottom of the cabinet below the crisper was actually correct. I just didn't equate "cup" with the black part that attaches to the fridge....since it doesn't look remotely like a cup. Once I undid the drain tube and was able to unhook this part it was obvious it and the tube from the fridge were both plugged with ugly looking gunk. Both have been cleaned now and resinstalled and waiting to see if this was the sole solution to the problem. You did good. Adrian
  • Adrian Snyder Jul 15, 2010
    I've already sent my appreciation in the note. We just had a mis-understanding and he was spot on for the solution.
  • Refrigerators Master
  • 22,326 Answers
You have solved it ,this is the largest amount of questions on here relating to this problem also the car AC system as well suffers from this condensation outlet blockage problem as well
Posted on Jul 15, 2010
    you mention the car AC system having this problem....how do you recognize that this is going on and how to resolve?
    thanks,
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Fridge is leaking water from top of fridge and water in bottom of fridge
The defrost drain hole is plugged. you must open that and then the water from defrosting will not pool up below the crispers in the bottom of the frig. Generic ice box Manual and more Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Whirlpool Refrigerators
How to clean/pull out reservoir in bottom of fridge?
If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
1. Remove crisper drawers from fresh food compartment.
2. Remove hex screw holding water tank to rear
bulkhead.
3. On rear of cabinent remove hex screws holding water
valve cover plate.
4. Remove plate and tubing away from cabinet to expose
water valves and tubing.
5. Disconnect water tube from secondary valve coming
from water tank, remove compression nut from tubing.
6. On front of unit remove toe grill and disconnect water
coupler going to water dispenser
7. Remove compression nut from water tubing on cabinet
side of connection.
8. From rear of cabinet pull water tube out of conduit
going to dispenser.
9. From inside of fresh food compartment pull tubing up
and out of cabinet to complete removal of water tank.
10. Reverse procedure to reassemble.
To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
