I have a Sharp AR-287 copier/printer/fax/scanner that has jsut come out of storage into a new office. The copier works fine but I don't know how to reset the destinations for the scanner and add the device as a printer to our network. I don't have any CD's for printer drivers and only have the copier operators guide and manual. Can anyone help?
  • 6,826 Answers
Http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Input ar-287 for the downloads available.
You should be able to download anything found on the cd-rom and possibly more up to date 'drivers' and software for your copier/printer/fax/scanner including the manuals, etc.
I wish you luck on this one.
Sharp is a pretty good product.
Actually, to answer your question more directly, I think that once you install the device on your computer, the scanner function should show up in the control panel as a device.
You can also add the device as a printer to your network, but in Windows 7 you have to logon as an administrator or have administrator rights on the logon (not guest) name.
In windows 7 it's easy to share printers than in previous versions of windows, but it's all in the help section as to how to do this for printers and faxes.
You should be able to access and print to any printer online, as long as you approve of it in your permissions and allow it to be 'shared' with the 'share' option in the printer's control panel.
I hope this helps.
Posted on Jul 15, 2010
  • sdibble Jul 15, 2010
    Thanks Duane
    unfortunelty in trying to install the prineter (via the Add-Printer wizard) it does not see the printer on the network. The printer is plugged in and the "green" light by the network plug is on and steady.
    I'm guesssing I need to do something on the printer control pad but the operators manual only has details on the copy functions.
    I found a service manual on-line but that looks too detailed, and does not cover install instructions for printing/scanning.
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
60 people viewed this question
jasbo
jasbo
