Question about Intel Motherboard
What is procedure for operating physiograoh - Intel Motherboard
    Scholar:
  • 78 Answers
Damn physiograohogists! They keep sending me tons of junk mail.
Actually there is no english word "physiograoh".
Therefore it has no operating procedure.
Posted on Jul 20, 2010
Looking for a workshop service manual for a 2010 Countax c800h
It appears they do not make a separate manual. They seem to offer various procedures and optimizations that you can perform on their website and some basic troubleshooting in the operating manual.
A link to Published Service Procedures:
http://www.countaxtractorspares.co.uk/help/countax/service-bulletins
A Link to the Operators Manual (that you may already have):
https://www.manualslib.com/manual/1068349/Countax-C330-Mini.html#manual
Jan 31, 2018 | Ariens Garden
Olds bravada only blows hot air
Is yours manual or Automatic HVAC system ? heating ventilation air conditioning . When is the last time you tried it ? did it work then , last year ? Where do you live south , north ? Have you had any refrigerant added lately ?
The Heating, Ventilation and Air Conditioning (HVAC) system is divided into three separate sections. The first, Heating, Ventilation and Air Conditioning, has all procedures that pertain to a HVAC component or function that is not specifically associated with the manual control system. The second, HVAC Systems-Manual, has all procedures specific to the manual control system.
Begin the system diagnosis with the:
Symptoms - HVAC Systems - Manual in HVAC Systems-Manual for 4.3 L without DTCs
Diagnostic System Check - HVAC Systems - Manual in HVAC Systems-Manual for 2.2 L with DTCs
Diagnostic System Check - HVAC Systems - Automatic in HVAC Systems-Automatic for 4.3 L with DTCs
The Diagnostic System Check will provide the identification of the control module(s) which command the system.
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Review the Description and Operation information to help you determine the correct symptom diagnostic procedure when a malfunction exists. Reviewing the Description and Operation information will also help you determine if the condition described by the customer is normal operation.
Apr 13, 2015 | 2001 Oldsmobile Bravada
Critical error at 5672
try starting the computer using your operating disk, choose to repair the operating system. when you get to command prompt type "fixboot" and the computer will write a new boot command if this fails repeat the procedure and try "fixmbr" to have the computer write a new Master Boot Record. If neither these work you can repeat the procedure again and try "bootconfig/rebuild" to have the computer search and attempt repair of any operating system boot configuration it finds. I would do these things in the order above as each procedure is a little more intrusive than the last.
Feb 07, 2013 | Computers & Internet
Well my battery of my mustang wint down and i had to chage the battery and my drivers window when it goes up it bouces bacj down to a 1/5 down and i want to know how to restore it.
NOTICE: Make sure no obstructions are present in the window system when carrying out this procedure.
NOTE: A battery disconnect does not require this procedure to be carried out unless the battery was disconnected while the window was operating.
NOTE: Excessive bounce-back (bounce-back that occurs with no obstructions present) may indicate a non-initialized window motor.
NOTE: Carry-out the de-initialization of the motor before initializing the motor.
NOTE: The motor will only operate in the 9-16 volt range. If the voltage drops below 9 volts, the window will not function correctly or may stop moving. If the voltage drops below 9 volts while the motor is operating, the motor will become de-initialized and will need to be initialized.
NOTE: The front window motors must be initialized whenever: a new window regulator and motor is installed, a new window glass is installed, a glass top run removal and installation or when carrying out any operation in which grease or lubricants are applied to the window system. A new front window motor is in a proportional up/down mode until initialized.
NOTE: The convertible rear window motors do NOT need to be initialized as they do not have one-touch up or one-touch down functions.
NOTE: All front window components (window glass, window regulator, window motor and glass top run) must be installed/tightened and adjusted to specification before carrying out this procedure.
NOTE: If this procedure is only partially completed, the front window motor remains non-initialized and only the proportional up/down functions operate. A non-initialized window motor may allow one-touch down operation, but does NOT allow one-touch up operation.
De-initialization then re-initialization
The motor can be de-initialized in 2 ways:
Disconnect the battery cable from the battery while the window is operating.
Remove the window motor fuse while the window is operating.
After the motor has been de-initialized, the initialization procedure must be carried out.
Make sure there are no obstructions present in the window system when carrying out this procedure. The door MUST be closed during this procedure (for convertibles, the top and quarter glass must be in the closed and up position), in order for the door window motor to initialize.
The windows must be in the full open position for this procedure to operate correctly.
Press and hold the window control switch in the UP position at the second detent until the window glass stalls into the glass top run for at least 2 seconds.
Once the top run is reached, hold the window control switch in the DOWN position at the second detent until the window glass stalls at the bottom of its travel for at least 2 seconds.
Cycle the window glass an additional 5 times to set the window soft stop for the down position.
Test for correct window operation by carrying one-touch up feature.
Good luck, if for any reason you can't give four thumbs up, please ask for more information. Thanks!
Apr 11, 2011 | 2005 Ford Mustang
Sir, please explain me the procedure of antivirus procedure
http://www.ehow.com/way_5758565_virus-protection-procedures.html.
hope this helps.DT
Oct 29, 2010 | Computers & Internet
Key fobs not working i have changed the battries on both
: If a double audible warning sounds during the programming procedure a system malfunction has occurred. Repeat programming procedure.
Obtain all keys fitted with remote control. Open driver's door. Operate headlamp high/low beam switch to flash high beam position and hold. Insert key into ignition switch, turn to ACC position. Ensure system LED flashes once and an audible warning sounds. Operate headlamp high/low beam switch to flash high beam position 5 times. Ensure system LED flashes once and an audible warning sounds. Programming mode activated: Press and release lock or unlock button on first key. Ensure system LED flashes once and an audible warning sounds to indicate correct programming. Repeat programming procedure for remaining keys. Switch ignition OFF and remove key. Close driver's door. Check operation of keys. Keys can also be programmed using diagnostic equipment
Jan 31, 2010 | 2002 Jaguar X-Type
My driver side window does not auto roll up anymore. How do I fix it?
Window may not be initialized. Follow this proceedure
Window Motor Initialization adobe.gif Printable View (96 KB) NOTICE: Make sure no obstructions are present in the window system when carrying out this procedure.
De-initialization
  1. The motor can be de-initialized in 2 ways:
    • Disconnect the battery cable from the battery while the window is operating.
    • Remove the window motor fuse while the window is operating.
  1. After the motor has been de-initialized, the initialization procedure must be carried out.
Initialization
NOTICE: Make sure there are no obstructions present in the window system when carrying out this procedure.
NOTE: The door MUST be closed during this procedure (for convertibles, the top and quarter glass must be in the closed and up position), in order for the door window motor to initialize.
NOTE: The windows must be in the full open position for this procedure to operate correctly.
  1. Press and hold the window control switch in the UP position at the second detent until the window glass stalls into the glass top run for at least 2 seconds.
  1. Once the top run is reached, hold the window control switch in the DOWN position at the second detent until the window glass stalls at the bottom of its travel for at least 2 seconds.
  1. Cycle the window glass an additional 5 times to set the window soft stop for the down position.
  1. Test for correct window operation by carrying one-touch up feature.
Mar 06, 2009 | 2006 Ford Mustang
How to set internet
You can call to your phone operator and ask about the setting. They will tell the procedure to get the settings.
The procedure varies from cellular operator to operator.
Hope this helps.
Feb 03, 2009 | Sony Ericsson P910i Cellular Phone
Acer 3690 Restore
I have all the procedure,but I will like to know if you want just to restore your operating system and if your operating system is Vista..
"Papirin"
Sep 06, 2008 | Acer Aspire 3690-2196 Notebook
Intel Motherboard Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
