Question about GE WHRE5260E Top Load Washer
I have a GE WHRE5260E1WW top load washing machine that will not spin, I hear a humming noise. I can move the controls from light wash, hit start, stop it, then another cycle, stop it etc. and eventually I can get it to start spinning. Do I have a control panel issue or do you think i have a motor coupling issue?
  • dagmarc781 Jul 16, 2010
    Since it is spinning sometimes but not always do you recommend that I purchase a control board first because my intentions were to go home after work today and start to tear apart the washer but if you think it is most likely the control board I will overnight one in. and if it is can you help me with a a link or part number to the correct part please. Thank you for all of your help
  • dagmarc781 Jul 17, 2010
    I will try all of the above. Have tested the pump and have found that it is bad so i am starting out with replacing that. Thank you for all of your help.
  • GE Master
  • 19,396 Answers
Hi.
Re:"Do I have a control panel issue or do you think i have a motor coupling issue?"
Neither one.
Before going for timer board or "motor coupler" (this washer use a variable speed motor and transmission system) the machine must be tested for more common failures that can cause the machine not spinning.
As first thing look for water at the bottom of the tub. If water is not being drained completely the machine will not advance to spin.
If there is a drain problem, look for blockage , checking drain hose at teh back, and checking for blockage at pump hose attachment, test pressure switch and ensure pump is working.
If there is no water, and drain is OK the pressure switch can still be responsible. If the PS is sensing an incorrect amount of water, then the washer will not advance to spin even if drain is OK. Try blowing into the pressure switch hose. Pressure switch is difficult to test, as this is done by reading Ohms on switch with tub full and empty, after disconnecting power during cycle. Jumping the switct won't be a good test, as the machine won't cycle. Before replacing the PS check the lid switch.
Top loader like this GE check the lid switch before advancing to spin. Common failure causing no spin is a defective lid switch. The lid switch can be easily tested by jumping its contacts.
If all the above does not work, then you may start thinking about the timer board. From description it does not look like a faulty control assembly.
Here parts:
Lid Switch PS269869
I have a GE WHRE5260E1WW - _.gifPressure sw. PS269820
Here all parts and diagrams for your model.
Regards.
Posted on Jul 16, 2010
  • 10,515 Answers
HI,
If the machine is spinning, draining and agitating, then it is more suggestive of a ' control board ' problem.Sometimes the humming noise is due to faulty pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 15, 2010
  • dagmarc781 Jul 15, 2010
Kenmore washing machine catalyst stops during rinse cycle
The hum you here is the probably the motor trying to turn, but it is about burned out. If it moves a little with a full load and more with no load, it is probably bad. If you hear a hum and the drum never moves at all you probably have a broken belt.
May 19, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine does not spin on spin cycle,only hear a humming noise.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | Kenmore Washing Machines
My Kenmore top load washing machine is stuck in
sounds like ur pump has gone out totally and the controller is bad cause its not filling the tub or is it if it is and just wont pump it out u have a bad pump
Feb 25, 2010 | Dryers
Just check whether are you hearing any humming noise from the machine fi you hear humming noise means kindly replace the motor of the unit
Jan 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops running
i found out what happened, i took apart the pump in the bottom of the washer and discovered a sock had gotton stuck in the filter. hope this can help some1.
May 05, 2009 | GE Washing Machines
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
GE Washing machine not cycling
"...can hear the electrical contacts trying to hit". The timer may be defective.
Oct 05, 2017 | GE Washing Machines
GE WHRE5260E Top Load Washer Logo
488 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
