Question about Zanussi 24 in. ZSF6150 Free-standing Dishwasher
We have a Zanussi that has been fine for 2 years but the last week it has turned a powdery white inside and on the door with all the dishes becoming chalky. There is rinse aid and salt. Hope you can help
  • 4,070 Answers
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 15, 2010
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
All of a sudden my dishwasher is leaving a white powdery film on the dishes and really bad on the utensils. It had been working beautifully. Is there something inside that might be clogged that I should...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Mar 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Making noise and leaving white film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
the white film is due to hard water. go to www.dishwasherfilter.com and get the new difi filter. it will solve your problem imediately and extend the life of your dishwasher. the product is amazing and guaranteed to work. very affordable
Mar 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Zanussi 24 in. ZSF6150 Free-standing Dishwasher Logo
170 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Starnley Johnwells
Starnley Johnwells
richochet
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
