Question about LG LRFD25850 French Door Refrigerator
My LG LRFC25750WW refrigerator collects water in the bottom of the freezer (bottom freezer) that freezes, then leaks over the floor.
This is a known problem. There is a drain that allows condensation to escape to the bottom of the unit where it will evaporate. Ice accumulates in the drain causing it to clog and the moisture drains to the freezer bottom.
The solution is to empty the unit and defrost it for 24-36 hours. The ice in the drain will melt allowing the unit to work as it was designed. To avoid future problems make sure the doors are always kept shut. Ours clogged after our son left the refrigerator door open on day.
Posted on Sep 23, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Yes, ohiomoto reply is probably the cause for this. If you need a guide with images, go here you'll see step after step how to solve this good luck Avi
Posted on Jan 29, 2011
Water is collecting and freezing on the bottom freezer.. Overflow water is leaking on to floor,
bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Mar 12, 2015 | Whirlpool Refrigerators
I have water collecting and freezing on the bottom freezer. The overflow is leaking on the floor.
Bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Water is collected at bottom of basket in freezer. What can I do ?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 11, 2011 | Jenn-Air JSD2789GES Side by Side...
Our lg fridge freezer leaks water on to floor every 2 weeks
If the water is collecting and freezing on the bottom of the freezer then the drain under the evaporator in the rear of the freezer section is plugged.
Nov 17, 2010 | LG Refrigerators
Water leaks into bottom of freezer. it re freezes, and then also
hi there,
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Jun 07, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRFD25850 French Door Refrigerator Logo
313 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
