Question about Compaq Keyboard
On the packaed bell lj61 how do switch the screen on/off from the keyboard?
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Dark screen when switched on
Try to adjust the screen brightness using your keyboard. If the brightness is at maximum, then you need to replace your screen because its backlight is dying.
Feb 14, 2014 | Packard Bell Computers & Internet
Wireless switch
Probably in BIOS to enable it.
In Windows to configure and activate it.
Jan 25, 2014 | Packard Bell Computers & Internet
I have a packard bell touch screen moniter and computer all in 1 and the keyboard just stoped working whats wrong and how can i fix it
add via USB an external keyboard, like me, because some keys are no more working on the bad Chinese used keyboard.!!
Jan 11, 2013 | Packard Bell oneTwo L A6524uk All In One...
I buy PC packard bell easynote_TS11HR-032FR and the touchpad does not work, when i use my pc for the first time.
Check this:
Many laptops with touchpads have a switch or a keyboard combo that will disable the touchpad. Look to see if there is a little button you can push located near the touchpad. Alternately, there is normally a Fn-special function key combination you can use. You press the Fn key and also the special function key that has a little symbol on it that looks like a touchpad. That can turn the touchpad on or off.
Aug 05, 2011 | Packard Bell 160240 Mouse
Hi.I recently bought a Packard Bell mini-laptop (model DOA150),But after installing all Windows XP updates and turning on password protection at the startup, the KEYBOARD and sometimes also the MOUSEPAD...
If cases when this happens you can use the on screen keyboard.
Bottom left corner you will have a blue icon called ease of access.
You can open the on screen keyboard from there.
If the keyboard is working intermitantly inside Windows this could be a driver issue and they may need updating.
Failing that it could be a loose connection.
Checked Packard Bell website for an updated driver if it still the same contact your retailr for a repair.
Apr 25, 2011 | Compaq Keyboard
Annoying bell/alert/alarm sound lol?
Goto control panel
Goto sounds and audio devices
click on sounds
and make sure everything is fine there
or select the windows sound theme from the drop down menu and click on save
Jun 07, 2008 | Toshiba Satellite A135-S4527 Notebook
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Dec 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Compaq Keyboard Logo
255 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
