Question about Nintendo DS Lite
Nintendo ds lite p6 connector installation instructions. I've tried 5 times and failed.
  • 83 Answers
Desloder old P6
tin 4 pads at rear of P6 location on Mobo
add solder to one tab ( holding tab)
place p6 in position
tack in place amking sure conductors of P6 are inline with the solder tabs
tack up other holding tab
with a CLEAN iron touch each connector of the P6 into the tinned conductor on the board - do NOT try and add solder or you'll just bridge the 0.5mm gaps!
DONE
or get it done at www.dsdoctor.co.uk
Posted on Sep 17, 2010
Ds games keep freezing
Occasional lockups with video gamescan happen from time-to-time and do not necessarily indicate a need for repairor replacement. If you are experiencing frequent lockups, or a particular gamealways locks up in the same area, please see the information below. Make sure you are using onlylicensed accessories. Unlicensed products and accessories do not undergoNintendo's testing and evaluation process. They may not work at all with ourgame systems, and they may have compatibility problems with certain games oraccessories. Check for visible contamination orforeign material on the connector pins of your Game Cards or Game Paks. Ifpossible, try the Game Card in another Nintendo DS or Nintendo DS Lite. If the game works properly inanother system, the problem is with your Nintendo DS Lite. (from nintendo troubleshootingguide)
Feb 23, 2011 | Nintendo DS Lite
My grand daughter has a nintendo ds lite which has a scratched bottom screen which I think causes the stylus not to register properly If this is the case,how much would it cost to either repair or replace?
Hi, bottom touchscreens are extremely cheap to replace. They are around £4 on ebay and are quite easy to fit yourself too. There are a lot of good guides on the internet on how to fit the touchscreen. I have fitted many of these myself, the only thing you have to be careful of is that you do not damage the P6 touchscreen connector when taking the screen ribbon cable out.
I hope this helps and if you need any more assistance I would be glad to help.
Thank you for using FixYa
Aug 24, 2010 | Nintendo DS Lite Console
Replace the case for nintendo ds lite touch screen stopped working
Hi did you replace the shell an now the touch screen isnt working
If so you either have damaged the P6 conecter where the touchscreen goes or it is not in far enough or needs a new 1 can be sorted for a reasonable price i fit a lot of them
Aug 04, 2010 | Nintendo DS Lite Console
Nintendo ds lite
It's not easy at all. My company does repairs on PSP, XBox 360, PS3, Wii, and PS2. But we don't touch DS Lites. The following company will do it for you at a reasonable cost:
http://www.consoledude.com
They do all of our DS Lite repairs!
Also make sure you get an OFFICIAL Nintendo shell case. Some of the aftermarket ones don't fit properly. The following website sells the shells:
http://store.richspsxparts.com/newcoornidsl.html
Apr 14, 2010 | Nintendo DS Lite Console
Powers on, Screen Flickers
This is a common problem, if you are lucky you simply have not connected up or clipped back in the touch screen cable into its socket properly (connector is numbered P6 on the motherboard) the small ribbon type cable plugs into it. If you are not lucky, like moi, you have broken the flip up part of the connector, but this whole part can be replaced from as little $1 (US dollar), perform the following keyword search on ebay: "Touch Screen Connector P6 For Nintendo DS Lite NDSL" however the connector has to be soldered onto the motherboard, obviously you would have to unsolder and remove the old connector, if you have soldering experience, its a trivial task, if you cannot solder it yourself, you could always ask someone who can do it for you. If successfull you could save yourself having to fork out for a new DS lite! Good Luck!
Jun 05, 2009 | Nintendo DS Lite Console
My DS Lite keeps flickering on the touch screen.
something has happened like a drop or something
believe me it doesn't take much to kill it
sounds like a lower screen problem
they are very sensitive .
Feb 21, 2009 | Nintendo DS Lite Console
Nintendo DS Lite power adaptor disconnection problem
There is a small latch on the connector that may be stuck. Try this. Turn the DS Lite upside down with the charger plug facing away from you. Press down the on the plug gently with your right thumb and with your left hand pull the connect away from the socket. FYI this should be a simple fit! Make sure the connector was not jammed in upside down to start with. It has a clear six sided shape to it!
Dec 23, 2008 | Nintendo DS Lite Console
Red ds lite screen
When the screen has a red hue there are two possibilities:
The screen is broken or the connector has moved.
The "water" is in fact the liquid crystal diplay that is broken.
Replacing the screen will cost about € 20
Here you can find the instructions:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Please rate!
Aug 20, 2008 | Nintendo DS Console
Reseating Touch Screen Ribbon Cables
The cable for the touchscreen is one with 4 conductors that connect directly to the overlay on the face of the LCD. The flat ribbon connector on the main board is quite delicate. The three connectors for the bottom screen are on the right side of the component side of the DS phat board. The touchscreen is labeled P6. On the DS Lite, the connector is closer to the R button.
Good Luck
Jul 08, 2008 | Nintendo DS Console
Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Jan 08, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Logo
473 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
