Question about Microsoft LifeCam VX-3000 Web Camera
Microsoft lifecam software change save locations
I am using a microsoft webcam VX-3000 and software lifecam 3.2. By default when you take a picture it saves the picture in a folder under my pictures folder in a lifecam folder. There is no way to change the location in the software. I was wondering if anyone knows how to change this thru the registry or else where any help would be appreciated.
gate0000
  • 14 Answers
SOURCE: Unable to change settings on Microsoft Lifecam VX-1000
uninstall then redo but make sure no folder in program files afer uninstall
Posted on Feb 22, 2009
SOURCE: tiene el driver para esta camara MICROSOFT LIFECAM VX 3000
i lost my web cam drivers plz help me
Posted on Nov 01, 2008
  • 814 Answers
SOURCE: Microsoft LifeCam VX-3000 Help on stickam?
You need to go to the micro-soft website www.microsoft.com and use their support section and see if they allow you software updates for expanded service with your camera. If they do then you can just download the updated software and start using your camera. If not you may need to check with the technical service and see what they require to get full use of the camera. You can also check the frequently asked questions and troubleshooting sections and see if the problem has been posted with a solution. I hope this helps you with your problem.
Posted on May 19, 2009
  • 3600 Answers
SOURCE: microsoft lifecam vx 3000 blurred outcome
You have to turn the outside ring on the camera and adjust it till it's clear. hold the camrea base and turn the outter ring it will move adust one direction then the other till you get a clear picture.
Posted on Oct 17, 2009
moleski
SOURCE: Microsoft Lifecam VX-3000-unknown video error on Skype
I tried the skype link given in Solution #1.
None of Skype's suggestions helped.
The problem child: Windows 7 (all updated) and current Skype.
I installed DirectX per Skype's suggestion.
Also found this link to MicroSoft driver for W7:
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=LifeCam&name=68A-00001&os=Win7_3264&lang=en
It's working at the moment. But the camera was working previously with this setup. Time will tell.
Posted on Dec 25, 2009
I lost my installation cd for my microsoft lifecam vx-3000 and i need o install it in order to get the webcam to work..i don't know how to get the software.
Giovanna:
Please download the drivers and software from the Microsoft web site.
You can start locating the files for your lifecam here: (click here)
Good Luck and Thanks for Using FixYa
Feb 16, 2011 | Microsoft LifeCam VX-3000 Web Camera
How do you change the focus on the microsoft lifecam vx-3000 the picture is currently all blurry
The LifeCam VX-3000 has a focus ring which you can adjust to make the image sharper. You can also try the tips recommended in the article How To Improve Your Webcam Video Quality.
May 08, 2010 | Microsoft LifeCam VX-3000 Web Camera
Microsoft lifecam vx-5000
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Dec 26, 2009 | Microsoft LifeCam VX-3000 Web Camera
Initialization error
Test your webcam here by hitting "Allow" in top window and assessing your webcam in left hand panel.
If it works here, you know the hardware is OK. Now you have to configure it to any program you want to use it in
SkypeIf you have problems when you use your webcam device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your LifeCam device as the default microphone. For example, select Microsoft LifeCam VX-3000.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your LifeCam device as the default Webcam. For example, select Microsoft LifeCam VX-3000.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
I do not know the second program ( explorer express) but there will be a similar arrange for making your Hardware default
Aug 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
I am new to using a web cam. I purchased the VX6000 and everything is working, however, the people I talk to on it only see static pictures of me (Skype).
I think what they are seeing is the photo you took with your webcam when you set up your account.
Make sure your webcam is is working OK and then check your settings
  1. Start Skype.
  7. Click Save.
Aug 20, 2009 | Microsoft Lifecam 6000 Webcam
Need software of Lifecam 1.4 (Lifecam VX-300).
I found the install file you're looking for. Go to this link and click on the download button to save the file. http://www.findmysoft.com/drivers/download-Microsoft-LifeCam-Series-1-4-WHQL-driver.html
Apr 14, 2009 | Microsoft LifeCam VX-3000 Web Camera
MicroSoft LifeCam 1.4 Installation to an eMac
microsoft Webcam VX-3000 Web Camera installation please i don't have the disk
Nov 18, 2008 | Microsoft LifeCam VX-3000 Web Camera
Genius webcam instalation missing my cd so plese tell me what is slution how can i install my web cam ?
To download the most recent version of the LifeCam software, follow these steps:
  1. Visit the following Microsoft Hardware Web site: http://www.microsoft.com/hardware/downloads/default.mspx (http://www.microsoft.com/hardware/downloads/default.mspx)
  2. Click Software for Microsoft internet communications (webcam and headset) products.
  3. In the Select type of product box, select Webcams.
  4. In the Select your product box, select your LifeCam VX-3000 (or model number of the product you are using).
  5. In the Select your operating system box, select your version of Windows.
  6. In the Select your operating system language box, select your Windows language.
  7. Click Go.
  8. Click the link to download the most recent version of the LifeCam software.
Don't forget to vote if this helps ... :D ... Cheers ..
Oct 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam VX-3000 Web Camera Logo
763 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
