Question about Garden
I have a simplicity legacy tractor with a 25hp kohler engine. after changing oil and filter a few hours later I started hearing a noise like a bad lifter. It is more noticible between 2500 and 3000 rpm. Is there an adjustment to the lifters or is this something else ?
SOURCE: Lifter clicking sound in 4.6 engine
it could be your tensioner. it sounds like a clicky squeak. sometimes it may go away but it always comes back. thats what mine is but i havent fixed it yet. i doubt you can grease it, you probably need it replaced. not expensive, at least the part should be under 100 bucks
Posted on Dec 29, 2008
  • 109 Answers
SOURCE: model#917.276020 25hp 48
On the bottom of the carb., there is an anti-after fire solenoid, take it off and make sure that it is working with the key switch, it should retract when the key is turned on and go back out when the key is turned off, if it doesn't check the red wire to make sure it is still connected
Posted on Apr 24, 2009
wilsodfarm
  • 986 Answers
SOURCE: Compact diesel tractor running bad. 24.5 hp 3
some of those had like a sediment bulb with a screen it before the fuel filter they are famas for pluging up
Posted on Jul 29, 2009
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
  • 61 Answers
SOURCE: Metal meshing sound when attempting to start,
stater gear is bad ck?
Posted on Sep 06, 2009
Kohler Command 14 OHV, Simplicity, riding lawnmower. oil is mixing with gas and blowing out valve cover breather tube and into air filter chamber. What's wrong?
The needle and seat in the carburetor are not sealing. If you don't want to have the carburetor rebuilt what you need to do is change the oil and install an inline fuel shut off valve in the fuel line so you can turn the gas off when the mower is not running or in use.
Apr 17, 2016 | Garden
Oil change
Take the old one out and get the numbers off of it or take it with you for reference. The amount of oil is probably 3 quarts but that can be looked up on cub cadet site.
Jul 26, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Backfiring and missing
possible couple of things
low battery voltage by the system not charging enough
overheating component in the ignition system--coil failing when hot
engine overheating- no air flow around head and cylinder fins from dirt and rubbish
May 26, 2017 | Cars & Trucks
change the spark plugs.
Jan 06, 2014 | Cars & Trucks
25 hp kolhler won't stay running
check fuel filter, it may be clogged, if so replace
Mar 03, 2013 | Simplicity Legacy XL 27hp 2WD - Kohler
Simplicity riding mower with 16HP Kohler engine stalls after about 15 minutes. Acts like it isn't getting any fuel, but it will run again later.
I have seen this problem a few times and this may not be the solution however, check the fuel filter. It may have melted and partially closed off the fuel supply. The routing of the fuel hose will cause the inlet end to bend slightly if it gets too hot under the hood.
Aug 24, 2012 | Simplicity 44in Broadmoor Lawn Tractor...
Valve clearances
mine has hydrodrolic lifters no adjustmetn
Aug 21, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman DGS6500 Garden Tractor 24 HP Kohler engine. Messages says CH6 Oil - what does it mean? Oil is full and new.
It means change the oil. It will come on every 50 hours regardless when the oil was last changed, then go off after a few hours.
Aug 28, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
313 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
