Question about Fisher and Paykel E522BLXEZ EZKleen Stainless Steel (1833 cu ft) Bottom Freezer Refrigerator
Fridge not keeping things cold enough
Dial on upper fridge part is set to the coldestsetting. Yet not keeping things cold enough. Milk & dairy products sour in less than a week?
We bought the home with this appliance in it. The home is 4 years old.
Can't find a manual for it. Can you suggest what might be wrong?
Thank you.
    Top Expert:
  • Fisher and P... Master
  • 49,172 Answers
Fridge coldest setting is 1
freezer warmest setting is 1
Posted on Dec 08, 2017
SOURCE: My freezer works perfect but
Warm fridge cold freezer problem fixed
In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
Robert
Posted on Dec 30, 2008
  • 19 Answers
SOURCE: Refrigerator not cold enough
yes, if theres a warranty on it, call the place you bought it and have them send out a service tech. you should not have to pay anything.
Posted on Apr 22, 2009
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
TheMobilian
  • 8220 Answers
SOURCE: Fridge Not Cold Enough
You could do the simple things like clean the dust and stuff around the compressor condenser. Check the condenser motor. Good air flow improves performance and cost nothing to fix. Of course if you are experiencing a defrost problem the air from below gets choke out with ice buildup around the evaporator area. If you have frost on the backside of the freezer section changes is you have a broken defrost heater.
Posted on Apr 19, 2010
caroldon
  • 17130 Answers
SOURCE: 3 year old fisher and
This is the main relay that is chattering and it can be due to the failrue of the relay if your compressor is cooling the fridge alright.
it will also be good to remove relay and check the contact, ,if bad replace. Also check the main capacitor of the motor and it can be faulty lead to poor starting and making the relay chattter..
Posted on Sep 23, 2010
Not keeping ice cream cold enough in freezer & milk and drinks in refrigerator are not cold enough
You need to change the settings on the thermostat. Its a dial setting inside or digital setting on the door. Lower the temperature until you are satisfied.
Feb 29, 2016 | Refrigerators
Samsung rf267 series refridgerator not cold enougheverything else works fine its just that the milk goes off and things go bad because it doesn't get cold enough
this could be your stat has gone or you have an insulation leak gas leak you will need a fridge engineer believe me it will save you loads a call out should cost you around 25 to 30 but its cheaper then any thing else ok
Oct 22, 2012 | Refrigerators
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
Fridge not cold enough to hold milk resulting in the milk becoming sour. Fridge temperature is 10 degrees C how can we make it cooler? We have already set the temperature to the dial 7.
Apr 19, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
The fridge is not keeping the milk cold enough- upper freezer is working fine
check for the air flaper for air. check if icing in freezer panel
Feb 14, 2010 | Refrigerators
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
Fisher and Paykel E522BLXEZ EZKleen Stainless Steel (1833 cu ft) Bottom Freezer Refrigerator Logo
50 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
