Question about HP OfficeJet Pro K8600 Printer
K8600 won't print tabloid after upgrading to Windows 7. I have installed the latest drivers and restarted the computer, but so far nothing has worked.
Win7 HP Tabloid wont print -
- Open the HP K8600 Printer from Devices & Printers
- Select Customize your Printer / Advanced Tab
- Click the 'Print Processor button at the bottom of the dialog
- Choose the "winprint" print processor option instead of the HP one.
Leave the Default data type as "RAW"
This should work with the current Win7driver (these are downloaded when you select 'new driver' from the advanced dialog and then 'Windows update' a couple of screens later. There is HP driver (V13 I believe from January( that has been recommended by others, bu I have yet to need it...
Posted on Nov 01, 2010
  • bobby_fisher Mar 15, 2011
    Thank you so muck wjones99
    i've been trying to fix this problem from 5 days ago and no one could figure out what the problem is even HP technical support assesstance.
    I owe you a big merci.
  • doane104 Jul 31, 2011
    This worked, I couldn't print Tabloid, but now I can. The only thing I lost that I can see is the HP preview that I had before. In devices and printers, double click to open, don't go to preferences with the right click.. couldn't find what he was talking about at first. Thanks so much!
We have a HP Officejet Pro K8600 at the office and have it on network via another computer, problem is when trying to print from another computer on the same network, the printer prepares the sheet bu
Uninstall the drivers and reinstall them. Restart the computer and check if the printers work.
If it works, then update the drivers using RadarSync to avoid from any errors in the future.
If no go, check your IP address.
I hope this helps!
David
Apr 12, 2013 | HP OfficeJet Pro K8600 Printer
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
I was using HP Officejet Pro K8600 Windows xp, and now I am using Windows 7, I feel there is a proble in the installation, please advise?
check you installer if is compatible for window 7.if ever not compatible.go to HP.com to find and download a new driver..
Jul 06, 2011 | HP OfficeJet Pro K8600 Printer
I cannot install my dell A940 printer using the CD to my Toshiba with windows 7
Often, older printers do not have drivers for Windows 7. Mostly because the manufacturer decided that this printer is too old to develop new drivers. The only possible solution would be to use Windows Vista drivers. Vista drivers are similar to Windows 7 and have worked for me in the past.
Mar 01, 2011 | Dell A940 All-In-One InkJet Printer
HP Deskjet F4480 will not print after vista to windows 7 upgrade. Ran HP printer diagnostic tool says driver conflict, uninstalled re-installed same problem, same diagnositics. Attempted to print test...
Windows 7 comes with basic driver built into the operating system (in-OS driver). With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. When you connect the product to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Follow these steps to install the basic driver in Windows 7.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use the following workaround procedures instead.
For more options go to LINK .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP Office Equipment & Supplies
I am running Windows 7 upgrade from vista and office 2010, I had problems associated with the upgrade which were resolved. I now have the same problems since I installed office 2010. The Lexmark status bar...
Uninstall the Lexmark software from your computer by following the steps in this link: http://bit.ly/cu3xvM. After restarting pc, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. To reinstall, download the driver using this link: http://bit.ly/cVGxkh (for 32-bit) or this link: http://bit.ly/b6TXD2 (for 64-bit). Thank you for choosing Lexmark.
Aug 25, 2010 | Lexmark X4550 InkJet Printer
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
It was printing ok in tabloid size paper, suddenly, after reinstallation of my winxp PS, it is printing halfsize on my tabloid size paper.
Having reinstalled the driver check both the printer and also the print driver for a zoom setting that would show as 50% as a default. This is most likely to be on the print driver setup on the PC. This can also happen if you get a combination of 'zoom to fit' and then change the orientation from portrait to landscape and vice versa so check this setting as well. You can avoid this by setting auto adjust for rotation from portrait to landscape and vice versa.
Oct 05, 2009 | HP OfficeJet Pro K8600 Printer
HP OfficeJet Pro K8600 Printer Logo
1,950 people viewed this question
Seeker5211
Seeker5211
