Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
We have a 23.6 cu ft no frost refrigerator
We have a GE 23.6 cu ft no frost refrigerator freezer. TFH24PR We want to replace the water filter but we cannot find it...please help.
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: I have two (2) GE
You can try to turn off your refrigerator from time to time but the biggest problem you are going to run into will have to do with remembering to turn it back on before it gets too warm and the food spoils.
Honestly it isn't something we would recommend. Instead you can turn the temp down a bit and make sure that it is always full with either food or gallon sized full water bottles to maintain the temperature inside even after opening the the door.
Just be really careful with lowering the temperature too much because the food can spoil. Instead try to keep it at the temperature that the instruction manual suggests.
However, as you would moving outside for 3 months, you could switch that OFF. Refrigerator plays a major part in chunk of your electricity bill ( on an average 16% ). So, on daily basis it is not advisable, but for 3 months it is recommended.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • 2180 Answers
SOURCE: We have a GE 22.2
if there's frost on the back inside wall of the freezer and the fridge is getting warm you have a defrost problem,or if frost is on packages and racks the door could of been left open or the door where the ice comes out might not be closing properly.if it's a defrost problem you could have a bad defrost fan motor,you wouldn't hear the fan turn on when you open the freezer door,a bad timer or board,you didn't send the model number,bad heater or thermostat or loose wire.
Posted on Apr 09, 2011
SOURCE: my GE mod#tfx20jrxd 19.7 cu. ft. is leaking water ...
water is leakinf from the frnt right bottom of my refrigerator model TFX20JRXD
Posted on May 08, 2011
GE 18.0 Cu. Ft. CleanSteel Top-Freezer Refrigerator - GTL18JCPWRBS Water isn't going to the ice maker even though the water supply is on
Locate and replace the water filter. It should be covered in the owners manual. If that is not the problem, then the solenoid that turns on the water supply is shot, at which point you are probably better off just buying a replacement ice maker.
Oct 02, 2013 | GE GTL17JBSBS 28" 16.6 Cu. Ft. Top-Freezer...
Water dripping from the back of the refrigerator
clean or replace the water tubing from the ice maker, mine had a bit of dirt from the water area. Did this and it worked fine.
Nov 18, 2012 | GE Profile 24.7 cu. ft. Top Freezer...
Smells like frost
Baking soda, follow the directions on the box for use in freezer or fridge.
Aug 04, 2012 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Why does the ice from ice maker have an awful smell and taste? Is there a filter that needs to be replaced?
i found that the previous homowners hooked the icemaker to soft water instead of hard water. Once I changed it to hard water, both ice cubes and water tasted fine.
Jul 09, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Frost on back of freezer does not seem to be cool enough
Sounds like a defrost issue. The frost is caused because the defrost element heater is not working. Ice accumulates in the coils and blocks the air flow in to the freezer/refrigerator. GE refrigerators have an element heater behind that back panel under the evaporator coils. They are quite simple and inexpensive to replace. Use a hair dryer to defrost the coils to make the swap easier.
May 23, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
GE TBX18JA. Water is collecting below the
defrest freezer drain is in freezer. use hot water and a turkey baster untill water flows thru drain.
Jan 18, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
