Question about Bose 3 2 1 GSX System
I have a problem adjusting bass and treble. I have too much bass when playing the TV so I adjust the bass down to get the proper balance. Then, when I play a CD, the bass is almost gone and I need to readjust again. Is there a way to avoid readjusting the bass every time I switch to TV or CD?
    Brigadier General:
  • 8,546 Answers
Figure out why the TV has so much bass. Look into its audio controls. I'd also consider attaching and listening to the TV-related audio directly and digitally through the Bose from the source(s) rather than through the TV and its questionable electronics.
Posted on Jul 22, 2010
How to adjust the pickup on a bass guitiar
It's a balancing act between volume and string pull. Generally I raise the treble pickup as close to the strings as possible without the strings hitting it while playing hard. Then play sustained notes and see if the pitch wavers from magnet pull. If so, lower the pickup a bit until the waver stops. Then ring up the bass pickup until the output matches the treble pickup. If that doesn't cause waver, your set. If it does, lower the bass pickup until it stops.
Feb 17, 2018 | Music
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
Oct 14, 2010 | Clarion DXZ665MP CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
Bose home theater
It may not have bass and treble controls, since most newer TV's now have these adjustments. Play around with your TV and see if you can find bass and treble adjustments from the remote.
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
Aug 27, 2008 | 1999 Porsche Boxster
How to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Jun 11, 2008 | Clarion RDB325D
Bose 3 2 1 GSX System Logo
632 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
