Question about Westinghouse L2046NV Monitor
Green screen I unplugged my screen for a min and when I plugged it back in the color is all off and its hard to see its so dark is there a way to reset this?
    Champion:
  • 200 Answers
There should be a reset in the menu on the monitor where you would change color, vertica,l etc... it will say reset or reset to factory.....if not try shutting down the computer completely and unplug monitor and pc for a couple minutes then plug back into electrical connection and restart
Posted on Jul 15, 2010
Toshiba tv has dark picture cant hardly see want get bright
If it's a old style projection screen pry off front grid, you,ll see a trapezoidal mirror this often becomes hazed smoke, dirt, ect. Make sure set is unplugged DO NOT ASSUME THEIR IS NO SHOCK HAZZARD BECAUSE SET IS UNPLUGGED(see capacitors) be careful and clean mirror with damp cloth and glass cleaner try not to spray as safety percotion, their are 3 tubes red , green, blue, green is th dominaent color if you know how turn blue HVU UP 1st( CLEAN picture tube lens 1st) These type of picture tube have clear poly glycol ( anti freeze) in lens unit to cool and is part of the optical system. I this fluid becomes contaminated then cost of repair may exceed value of unit, then increase red value I just thought you may bee able to do the color via menu not sure, if picture has a green tent at start this should help good luck , lot me know what you see.
Aug 18, 2014 | Televison & Video
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
I have a Sony grand wega KDF-50we655. The picture was dim/dark etc. as suggested I replaced the lamp. Not much change. I did notice when the screen was White the left side had green in it and the otherside...
These tvs are LCD they have no tube to fill or color wheel.
You need to clean the glass light filters and lens.
If you remove the back and unplug the 9 plugs that go to the fans and LCD board/light housing it has 4 screws that hold it in to the front of the tv. 30 min Job.
Dec 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Pic freezes, goes dark w/sound then back on
By what you have said your color wheel can cause this when it stops running .Pull back off and watch what is happening when you turn set on.
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
Ezonics IcatchVI PC Camera Ez307 help????
Something probably corrupted your webcam software or configuration. Probably the best is to uninstall and reinstall the drivers and the software.
Please check http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
The drivers should be here: https://www.shopezonics.com/Articles.asp?ID=108
Jules
Oct 16, 2008 | Ezonics EZCam Plus Webcam
Way too dark
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Sep 26, 2008 | Pioneer SD-643HD5 64" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Westinghouse L2046NV Monitor Logo
385 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
