Question about Maytag MSD2756G Side by Side Refrigerator
Maytag fridge, side to side. Model# MSD2757AEB Bought on Sept. 1999 The bottom of the freezer forms a deep layer of ice; I remove that ice, but it keeps ddoing the same. The water drips from the bottom grill on the back wall inside the freezer, to the floor of it where it forms the ice. I would like to have an idea of the price to repair it to decide if it is worth it or not. This fridge already needed two repairs, about two years ago, that resulted in $400.
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
Maytag side by side model MSD2757AEB suddenly stopped working. The freezer is thawing and dripping fluid on the bottom left side of fridge. It is still running and is putting out cold air, but it doesn't...
Could be that you have a bad freezer (defrost) thermostat and it is not "shutting off" after a defrost. Do you feel heat (DON'T touch the panel) near the bottom rear panel inside the freezer? Also, could be a Adaptive Defrost control problem.
http://refrigeratorheaterrepair.blogspot.com/
Dec 28, 2010 | Refrigerators
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
94 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
