Question about Microwave Ovens
Sensor problem - Microwave Ovens
  • 1 more comment
  • mickjeff Apr 21, 2008
    Sharp R-874 the display continually flashs sensor whereas it never used to so I am assuming it is trying to tell me something.
  • mickjeff Apr 24, 2008
    Thanks for your help I think a new microwave is needed.
  • William Miller
    William Miller May 11, 2010
    Please write back with more details and your brand and model number.
  • Microwave Ovens Master
  • 9,098 Answers
Okay, that would be a UK model.
Your absolute humidity sensor has failed, or the temperature sensor, whichever it is equipped with.
I would visit http://www.sharp.co.uk/pcat/support if you want to find a servicer or spare parts distributor.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 23, 2008
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
Error code s5
see this step and fix it. God bless you
SE or 5E codes are usually sensor problems. it is also a catch-all for a keypad shorting issue. if it's either issue then it will need professional service. to test the sensors:
SENSOR TEST (QUICK TEST)
1. With 2 fingers touch and hold the following pads at the same time :
pause and cancel
2. Observe diagnostic number in display (Numbers approximate)
ex) 33 (Vs) 39 (Vout)
? Vout Vaule : 10~150 (Normal-verify with "detection test" )
? Over 150 or Less than 10 (Sensor failed. Check connection of Sensor.)
Oct 15, 2012 | Samsung SMH8165STE Microwave Oven
When trying to Popcorn the touch pad is dead and comes up on the display F4?
Its you humidity sensor causing the code:
F4 - Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds, it says to replace the sensor.
You can order it in http://www.repairclinic.com/PartDetail/Sensor-or-Thermistor/253789
Hope this helps.
Aug 11, 2011 | Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ultrawave with Hood fan
You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 04, 2008 | Microwave Ovens
Humidity sensor
replace the humidity sensor. is it a GE?
Dec 30, 2007 | Microwave Ovens
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
