Question about Vivitar ViviCam-X30 Digital Camera
When I plug in the usb lead to download the pics, the camera screen goes black as if off, i unplug the usb lead and the camera resumes normal function, do i need a new usb lead or is the problem something else.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 01, 2011
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
Downloading Pics to PC
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Apr 14, 2009 | Olympus Stylus 800 / ? 800 Digital Camera
Pc will not recognize that the camera is connected
Apr 04, 2009 | Fuji FinePix S5100 Digital Camera
Canon Powershot SD1000 Uploading Pics To Computer Problem
Since your two cameras have the same problem with the same computer, I would like to suggest you to connect those cameras to another computer. It looks like the problem is on the computer side.
Apr 04, 2009 | Canon PowerShot SD790 IS Digital Camera
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
Dec 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera capture screen is black (blank)
Normal 0 Try this:
In some cases, the preview capture may not appear only a black view.
To fix this:
- Unplug the web cam and plug it back in.
- Or -
Lower the video resolution of the.
Hope this helps. Bud
Jun 24, 2008 | Logitech QuickCam Communicate STX Personal...
Cybershot DSC-S700 goes black when plugged into USB
Try your camera on another PC and confirm either your PC has problem or camera...
Jun 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot S700 black screen when USB cable is inserted.
try going into the menu and doing a camera reset this corrects alot of connection issues. hope this helps.
Mar 02, 2008 | Sony Cybershot S650 Digital Camera
Downloading
For Windows 98:
Firstly you need the software CDROM that was supplied with your camera.
Secondly, you need a lead that has a connector on one end that plugs into a socket on your camera and has a USB connector at the other.
If you do not have the software CDROM, go to the manufacturer's website, click support and find a download of the software for your particular camera. If it isn't available you have a problem!
Install the software, it includes a driver which your computer needs so it can recognise your camera. Run the software and follow the on screen instructions. At some point you will need to connect your camera to your computer. Do not connect your camera until your computer tells you to. Use one of the USB sockets. This is a small rectangular shape that will match your lead. If all goes to plan, your computer will display "found new hardware." Just follow the on screen directions. You may be asked to restart your computer at some point, this is normal.
Hope this helps......
Feb 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Vivitar ViviCam-X30 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
