Question about Freezers
Fridge freezer lights up but not working freezer defrosted food spoilt
  • 382 Answers
Dear sir/madam
i think its low refrigerant problem please contect to your service technician for refill refrigerant i n you r freezer. i hope after that your freezer will remake ice there ,
hope answer the question
thank you
please vote!
Posted on Jul 18, 2010
Freezer drops in temperature and food defrosts; freezer then re-starts and re-freezes food
Hi, The unit is sticking in defrost for too long...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | GE Freezers
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Frigidaire Fridge/freezer works then doesn't work???
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
Sep 23, 2009 | Frigidaire Freezers
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Electrolux frost free fridge freezer not workinge
think your frig heater or terminnator is bad,all this is behind the freezer panel,also but i'am not sure your frig. might be stuck in defrost,you find this out by pulling the frig. out and listen for 25 minutes to see if it cuts on,if you hear it running already then it's one of the other problems,hope this helps-mike
May 29, 2008 | Freezers
Freezer not getting cold to freeze
ok if this fridge uses a defrost timer, it's probably stuck on defrost or the defrost thermostat is faulty also check the number on your thermostat it its on a low number the fridge won't cool properly also a refrigerant leak could be suspected.
May 17, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
