Question about HP Photosmart C5280 Printer
I would like to scan as a PDF document. In the scan menu I only get 2 options. scan and reprint or scan to memory card??? Any ideas would be greatly appreciated. Thanks.
  • HP Master
  • 6,993 Answers
What Operating system are you using?
Windows XP: Go to Add Remove Programs under Control Panel
Windows Vusta : Go to Programs and Features under Control Panel
Check if you have OCR Software listed in there
If there is, uninstall it and run the installation cd for the printer and click on Install more software or just do the recommended / easy installation
If there's no OCR software, run the installation from the cd to install it
The end point is, just make sure that the OCR software is either refreshed or reinstalled
Hope that helps.
Posted on Jul 15, 2010
Scan to Computer is not one of the listed options. The only choices on the scan menu are Scan & Reprint or Scan to Memory Card. I need to scan and email documents but can't seem to get the ability to...
Did you install the HP software that came with the scanner? I believe it is called the "HP Solution Center". If so, you can open this program to scan. Once you scan the item, you will have the option of where to save the file.
Feb 28, 2011 | HP Photosmart C6280 Printer
How to scan a document to my computer
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Apr 08, 2010 | HP Photosmart C6280 Printer
I am trying to scan a document to email
In most cases, you want to scan to file and save the file in a folder of your choice. I have a 7310 xi all in one and I have a folder on my desktop named scans. When I scan a pic or document I save it as a jpg (pic) file or a PDF (document) file to that folder. Then when I email someone, I attach the file using the attach button on the email page.
Aug 31, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scanning
Right click on the card in My Computer.
Click Properties, Uncheck READ ONLY
Jun 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Wanting to scan from scanner to computer
this happened to me too. i don't know how to fix it on the printer, but i scanned it through the computer. i went into the hp solution center, went to the scanning section, and told the printer to scan it from the computer. it worked fine. that way you don't have to save it to a memory card or anything. they went to the same folder all my other scans go to.
Jan 13, 2009 | HP Photosmart C4150 All-In-One InkJet...
Scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Aug 31, 2008 | HP Photosmart C6280 Printer
HP Photosmart C5280 Printer -scanning
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
My new hp photosmart c6250 will not print to my computer. the menue only gives the option to reprint or scan to memory card
I reinstalled the program and will control the printer from my computer. The scan menu still does not say, 'scan to computer', as the basic guide book says that it should.
Jul 17, 2008 | HP Office Equipment & Supplies
HP C6180 won't scan to word or document viewer etc etc
the save as function is in the print/scan manager, not the software..you'll need to point it to where you want it to save, and also what format
May 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
I'm trying to scan a picture and save it to my computer. I read the directions, it says to press scan menu.Then press scan to computer but, when I press scan menu it just has 2 options. Scan and reprint...
me too. What I just did, was open up word and then pressed scan. That worked, so maybe open the place you want the scanned item to go to and it will go there. You can tell I'm not a techie.
Apr 08, 2008 | Office Equipment & Supplies
HP Photosmart C5280 Printer Logo
48 people viewed this question
Ben Johnson
