Question about Husqvarna YTH23V48 23HP Lawn Tractor 960 43 0086
Will not go up inclines
The mover does not go up inclines. It will eventaully stop and it seems to chatter out of the right rear. I have replaced the drive belt already still no change. It will work for the first couple times and then as it warms up it slows down and will not pull its own weight up an incline. Do I need a new rear differential. Are there internal parts avaialble if it need to be rebuilt? Please help.The mover has 200 hours on it.
3 Suggested Answers
SOURCE: Drive belt?? is slipping and not pulling mower up
This is a good time to check your belts tensioner for free movement and good spring tension. If the tensioner is good replace the belt.
Posted on Oct 11, 2010
muffteck
  • 202 Answers
SOURCE: Tractor has no power on
ck your fuel filter or fuel pump if it has one timming may have got off ******** to much
Posted on Nov 13, 2011
Truma motor mover S single axle problems
that is how a diff works
exactly what is the equipment ans what is the problem
what is a truma motor mover
Jun 24, 2017 | Televison & Video
Think i need to bleed abs system on ford expoler.
Sounds like the abs master cylinder area is in need of replacement if the abs fuse is removed and stops better.
Chattering can occur in an abs system when the system senses wheel lockup on that wheel and attempts to anti lock that wheel.
Could also be a wheel speed sensor not working, properly.
Hope this helps.
Jul 11, 2010 | 1997 Honda CR-V
Chatter feeling when under acceleration
Not sure what problem is but my 97 does the same thing it has a rattle or chatter at low throttle and deceleration. Did you ever figure out what the problem was?
May 26, 2010 | 2005 Yamaha V-Max
Feels like chatter in rear end when accelerating 2004 f150 4x4
Check the "U-Joints" on the drive shaft and or rear wheel/axle bearings.
You MAY need a little help as the wheel(s) needs to be of the ground to check axle bearing. Grasp top and bottom of the tire and wobble it in and out.
Dec 20, 2009 | 2004 Ford F150
2004 Ford F-150, my rear differential seems to be chattering when I turn left or right from a stop. Do I need to replace clutch packs or just change differential fluid and add modifier?
start with a fluid change.its the cheapest. chk the fluid as it comes out for metal flakes. you may have sticky parts. drain , fill with diesel and turn tires by hand, let sit for half hour and turn the tires again.do this three or four times then drain and replace fluid and modifier.
Oct 31, 2009 | 2004 Ford F150
My 1998 Cherokee SE with 185,000 miles seeme to shudder or slip as you accelerate from a stop. It seems to come from the rear end. What do you think
What seems to be coming from the rear is more likley coming from the transmission. The main pump within the tranny wheres down after high milage. When the pump weakens it is unable to pressurize the drums within the tranny and the clutches slip causing a chattering feeling throughout the vehicle. Time, most likley, for a rebuild. Thank you, Dana
Sep 30, 2009 | 1998 Jeep Cherokee
Differential chattering or grinding niose
hello i will help u.there is an additive you can add to the differential to stop this problem.you can find it by going to a good auto parts store.But otherwise your noise is common.and not a major problem.
Mar 10, 2009 | 1997 Ford Expedition
Squeaky Urban Mover rear brushless motor hub
lube the ball bearings or change them out compleatly
Dec 28, 2008 | Hybrid Urban Mover Cruiser Bike
BRAKE ALARM, BRAKE FAULT
Check brake fluid level and top up if required.
disconnecting ans connecting battery some times solves the problem.
Oct 22, 2008 | 2003 Volkswagen Passat
Husqvarna YTH23V48 23HP Lawn Tractor 960 43 0086 Logo
64 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Mike Squire
Jay Finke
Jay Finke
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
