Question about Fellowes P600C-2 Shredder
Fellowes P600C (NOT -2) Gear (Steel)
Like everyone else with the fellowes P600C, I am looking for a replacement gear. The only difference is that I have a P600C (NOT a -2) with steel gears. The gear that meshes with the motor drive gear is missing a few teeth. Although this unit is pretter old I would very much like to repair it if possible. If any one out there has one that perhaps the moter has burned out, I would be willing to purchase the gear box from in.
Thanks
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
SOURCE: short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Posted on Aug 26, 2008
  • 32 Answers
SOURCE: I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Posted on Aug 31, 2009
  • 610 Answers
SOURCE: My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Posted on Nov 16, 2009
  • 4 Answers
SOURCE: My Fellowes p600c-2 shredder will only run in
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Posted on Jan 18, 2010
Testimonial: "This solution worked for me."
Plastic GEAR 5403 07-1 B1
Here is a link where you can find a replacement: http://www.sportslinkup.com/shop/0-Fellowes-gear-1.html (Part Number 205993 OEM Fellowes Shredder Gear Kit for Model P-55C). They have the whole gear assembly.
I need the same for my P-57Cs shredder (broken stage 2 gear 540307-1. Hope it helps, good luck!
Dec 04, 2010 | Fellowes Powershred P-55C Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
The plastic gear in my Fellows Powershred PS 60CC paper shredder is ruined. Is it possible to buy a replacement gear anywhere?
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Oct 06, 2009 | OfficeMax 0M96431 Shredder
Fellowes shredder crc 32080 plastic gear stripped, need new one. what is the part #?
Made in China..same as made in Japan 50 years ago...junk...Thank the big box stores for the ****..Best Buy, Wallmart, Staples and don't forget your new job at McDonalds........
I bought an INIT tore up a gear also JUNK JUNK JUNK
Everyone of them will telll you parts UNAVAILABLE>>>>>>>>>>>
Jun 12, 2009 | Fellowes P400C-2 Shredder
Missing wastebasket to Fellowes Shredder
I have a P600C-2 wastebasket - and the unit only runs in reverse. We need to put our two pieces together!
Mar 08, 2009 | Fellowes P600C-2 Shredder
Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
May 16, 2008 | Fellowes DM8C Cross-Cut Shredder
Shredder no longer runs
Fellowes Customer Service is the best in the business call them at 1-800-945-4545
Dec 06, 2007 | Fellowes P600C-2 Shredder
Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
Fellowes P600C-2 Shredder Logo
51 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
