Question about Cameras
I JUST BOUGHT A NEW MEMORY CARD FOR MY VIVICAM 5386, AN I INSERTED THE CARD AND NOW THE CAMERA READS - CARD ERROR
  • maddogb Apr 20, 2008
    NO HELP YET
  • 13,433 Answers
The card needs to be formated.
Posted on Apr 20, 2008
  • Ekse Apr 20, 2008
    if you are able to use the camera with the card in it then browse to the settings and select format the memory card.
  • Ekse Apr 20, 2008
    also if your pc has a cardered
    put the card in the cardreader, then on the computer
    go to my computer
    select the card, right click, and format
Sd card error memory
Your card has likely failed. If you have information on it you should use recovery software to recover the data and then throw away the card. :(
Diane
NYC Photo Safari
Dec 20, 2013 | Vivitar ViviCam 5386 Digital Camera
Card error when i place SD card into slot
Are you sure it's an SD card, 2GB or smaller? The 5386 won't work with higher-capacity SDHC cards.
Feb 23, 2013 | Vivitar ViviCam 5386 Digital Camera
I just bought a 4 GB memory card for my camera and I cannot get it to take it. I tried to format it and it will not allow me. Any suggestions?
The 5386 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jun 10, 2011 | Vivitar ViviCam 5386 Digital Camera
Says Card Error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
May 17, 2011 | Vivitar ViviCam 5386 Digital Camera
MEMORY CARD
can you proceed to take pictures?
Apr 20, 2008 | Vivitar ViviCam 5386 Digital Camera
CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Vivicam 5386
It sounds like the bulb just simply burnt out. Before I spent any money on the camera, I would first reset the camera back to factory settings and try again. The cost of replacing the bulb might be more that the cost of a new camera!
Jan 30, 2008 | Vivitar ViviCam 5386 Digital Camera
I dont have a disk to download my pictures
Very easy. I just bought a friend a used one.No software. Just buy a card reader that fits into your USB port.Insert SD card and download to your computer.No canles needede.
Nov 20, 2007 | Vivitar ViviCam 5386 Digital Camera
Vivicam 5386 copying images to memory card
To copy pictures from memory to your memory card turn your camera on and press the button above the menu button. This will start showing the pictures already on your memory card. Next, press menu and the down arrow. This down arrow is located on the round button with the "OK" in the center. Your choices should be DELETE, SLIDE SHOW, PROTECT, QUALITY CHANGE, RESIZE, and the one that you want,COPY TO CARD. Press OK and the camera will copy pictures from internal memory to the memory card. This information is on page EN-62 and EN-63. I know that this works because I was testing the information as I was typing it!
Oct 02, 2007 | Vivitar ViviCam 5386 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
