Question about Intel D865GLC Motherboard
I just bought a mother board for my computer and it picks up the hard drive and while installing windows xp pro it stops cause it loses the hard drive
    Champion:
  • 200 Answers
You must have a sata hdd..........if so you will have to put in a driver for the hdd to work .......................when you start the setup to install windows from the xp cd...................you will see when you start the setup disk it will tell you to press F? button if you have a 3rd party driver unfortunately it will ask you later for a floppy with the driver on it...therefore you will need to get the driver from your cd that came with the MoBo or online and put it on a floppy disk and most new computers don't have floppy if yours does then all is well if not then you must get an external floppy that will work from USB just to install the driver....................I would enter the BIOS and see if there is a setting to automatically set the sata or raid settings for your HDD first usually F2.......will enter the BIOS..... BUT, .Be VERY CAREFUL a wrong setting change can cause your PC to not boot at all so write down everything you change and what it was before you changed it and only do 1 or 2 things at a time.....usually F10 saves the BIOS settings or on exit the computer will ask to save your changes.
GOOD LUCK
Posted on Jul 15, 2010
Hi I have a windows xp pro and my mother board is a ASUS A8V-X and it gave me a error message saying that I needed original cd that came with it i am assumeing that it would be the mother board i cant...
You can find manuals and drivers at the Asus site >> www.asus.com But in the position you are now and your computer wont start try do this
Start it at safe mode pressing and holding the F8 key while booting. Use your original Windows XP pro CD to repair/restore your windows installation
Just follow the onscreen instructions.
If that wont work you may need a technician to remove your had disk, take copies of any usefull data you may have on it, reformat your hard disk and make a new windows installation.
Try to upgrade to windows Vista.
Jul 19, 2011 | Computers & Internet
Hi I'm having problems installing windows 7 on my computer I think it may have something dealing with my motherboard I m running a MSI P55M-GD41 mother board with intel i5-661 processor and 4GB of 2 2GB...
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 24, 2010 | MSI P55MGD41 Motherboard
Mother board is ak77 pro 133 vt8233 will not run xp proI
The BSOD (blue screen of death) usually means that a computer component has failed. This could be a hard disc drive, a memory module, the cpu, or the motherboard. I would start by checking out the hard drive first. See if it is spinning and not making any clicking sounds. Try replacing it if you have another one. Then check memory and cpu. Some people actually like having an old computer hanging around. They install Windows 98 in it so they can play old dos games and games that don't require a blazing fast processor! Good luck...Hank
Jan 09, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Reinstall Windows XP Pro without losing my data
There is a free program that will allow you to view and change your current product key. It is called Magical Jelly Bean Keyfinder.
The link to this software can be found here. Go to download the latest build on the right side of the page, then run the program. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Professional
No sound can
hello. sir. i have lost sound from my lap top Compaq presario C700 after installing windows XP. kindly help me. my laptop is also showing pproblem during installation of hard drive for same driver, every time i turn on my laptop. i donot have the installation mother board for the same laptop
Jul 13, 2008 | Compaq Ensoniq AudioPCI Sound Card
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Lost sound on intel p4 compaq. Need to download driver
This will take you to Intel's download site for the 865GV motherboard. Do not be thrown off by the title on the site, D865GVHZ. These drivers wil work for you.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1704&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Luck!
Please vote.....
Jan 13, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hard drive not found
When you boot the computer go into the setup menu and check to see if it seeing the drives.
Dec 14, 2007 | Samsung StarGate STG-31271A Hard Drive
Intel D865GLC Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
