Question about GE Cooktops
Need to replace switch and burner on a jp660wv1ww the burner is a combo halogen and radiant burner original shorted and took out switch instruction on burner have me removing a lot of wires and doesn't seem right instructions don't give any schematic to rewire burner any schematics would be helpful at this point thnx
  • 106 Answers
SOURCE: Initial DTV-171 Schematic
try to find it on :www.eserviceinfo.com
Posted on Feb 28, 2008
SOURCE: Schematic
Have you try this link? http://www.bunnomatic.com/pdfs/commercial/manuals/39338.0000.pdf
Hope this will help you
Posted on Feb 29, 2008
rickzilla
  • 706 Answers
SOURCE: Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Nov 25, 2008
  • 32 Answers
SOURCE: 1996 Dodge Ram Factory Trailer Wiring Schematic
all you need is a cheap continuity tester, any one to help tap on the brakes..7pin is just like the 4 pin w/extra power wire for acc.lites,electric brakes.when you buy the 7pin rec.,comes w/wiring schematic standard to all trailer rec.- you can do it..kev-mn.
Posted on Dec 10, 2008
  • 222 Answers
SOURCE: kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Posted on Jan 27, 2009
Inner burner-- front right burner - does not heat up
you have either a bad switch or a bad element. If you plan on repairing this yourself, turn off the power to the unit BEFORE removing it from countertop. A continuity tester will be needed to properly test components. Nice Saturday morning homeowner project.
Mar 07, 2016 | GE Profile 30" Electric Self-Clean Drop-In...
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
The front right burner is not working
If the radiant burner is not working, but the other 3 are, then you will need to replace the burner with this part.
Feb 09, 2011 | Frigidaire 31 in. FEC30S7E Electric...
I have a Jenn-Air cve3400 cooktop. The dual radiant burner doesn't work properly. The inside portion of the burner doesn't work by itself or in tandem with the outside portion of the burner. Is it the...
I just went thru this problem. There are TWO possible switch replacement parts. one is 12002422 and was my correct replacement number.
12002125 was the WRONG part..would not work no matter how you wired it. the failed switch being replaced was part number 7403p406-60. 7403p851-60 will NOT work.
my serial # was 12284711qz
call Jen air customer support and give your serial # and switch part # to get the correct part and diagram... Jenn air changed parts and wiring in the middle of a run.
Aug 14, 2010 | Cooktops
Radiant cooktop stays on at low settings. fix?
it is the burner switch that needs to be replaced.the thermocouple function is built in the switch.
Aug 17, 2009 | Cooktops
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Cooktops Logo
18 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
