Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
How to dual boot xp and vista? - Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Jul 15, 2010
    Hi, Do you know anything about partitioning hard drives? This is the best way to dual boot from one hard drive partitioned into 2 or 3 partitions.
  • Robin ray Derro
    Robin ray Derro Jul 15, 2010
    if the partition1 is xp and the partition2 is vista,i only have to do is to choose the operating system in bootscreen?
  • Robin ray Derro
    if the partition1 is xp and the partition2 is vista,i only have to do is to choose the operating system in bootscreen? am i right?
  • Biostar Master
  • 4,806 Answers
First of all partition a drive up. Make sure its a large capacity drive, something well over 100GB.
Boot the computer with CD/DVD set as the first boot device and pop the XPhow to dual boot xp and vista? - mag-glass_10x10.gif CD in the drive and allow setup to begin. When you come to the screen where you select the drive partition you should see the drive listed with all the space listed as unpartitioned. If the drive was in use previously, you'll need to delete all the existing partitions. To do this you'll have to hit the 'D' key followed by the 'L' key. The screen instructions will be visible to guide the process.
Once all the existing partitions are deleted the display will show the total unpartitioned disk space.
Hit the 'C' key to create a partition. Personally i partion mine to 80GB (81920MB)
On the newly created partition, (not the raw one) install XP on that. Carry on with the installation until its final restart, it will be a light blue screen.
Quickly pop the Vista disk into the drive and start the Vista install. When it askes where you want Vista choose the unallocated partition. If you let XP load up first then you will not have the dual boot option on start up.
If you have done this correctly then each time the computer restarts during Vista install you see a boot message on screen saying "older version of window(XP) and Vista.
Lets Vista fully install right up until it loads the welcome screen. Then you can restart the computer, choose older version of windows to complete and load the XP operating system.
You then have to switch between them both to install drivers, software etc.
If you want to use both operating systems at a time then you need a virtual operating system installed but they are not that good as memory is kept at a minimum.
Good luck and please post back if you need anymore advice.
Regards.
Posted on Jul 15, 2010
Testimonial: "in making a new partition what should i choose extended or primary? thanks a lot!!!!"
  • Lee Hodgson
    Choose Primary partition because both partitions will have an operating system on them.
    Champion:
  • 200 Answers
You must use 2 partitions ........usually you can put vista in after you install xp and it will give you a dual boot screen when you start if it doesn't...........download a program called (vistabootpro3.3) or similar it has the ability to change the boot up so that you can use the 2 operating systems together ..................changing the boot.ini on the xp will not work as vista uses a different boot process.
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
How to install xp on this unit from vista
You have to format the hard disk before you can insall XP on a Vista machine, or you can try to install a dual boot system. Go to Microsoft.com and search for dual boot system help
Jan 29, 2010 | Computers & Internet
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Dual boot xp and vista on one hard disk
http://majorgeeks.com/VistaBootPRO_d5625.html
from here download vista boot pro ..and install it..there u can find option to add OS MENU while booting...
Feb 12, 2009 | Microsoft Windows XP Professional
Wish to dual boot vista home premium and windows xp
to achieve dual boot both XP and Vista, first u need to install xp and then vista on it as a fresh copy
Dec 24, 2008 | Microsoft Computers & Internet
Video card not working with xp sp3
The drivers for XP and Vista are different. You will need to install the drivers for XP as well as Vista for dual boot operations. Make sure you install the XP driver in the XP partition and the Vista Driver in the Vista partition. This should solve the problem.
Dec 20, 2008 | Computers & Internet
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I D: is format than also first time starting two option xp or vista than I want vista's option remove please...
hi,
To remove starting option boot with XP and go to run type cmd. then go to c: prompt. type edit boot.ini and remove the line that refers the vista. and save it.
Aug 03, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dual boot
Hi abc_19 ,
Before I answer your question , let me tell you that you need to back up your data.Also, make sure that your system hardware supports Vista.
You also need to have genuine windows XP and windows Vista disks handy with you.
1. Partition your hard drive. In Windows XP, using the $50 PartitionMagic or (according to one of our readers) the free GParted Live CD, create a new "primary" partition to install Vista on. Make it at least 20 gigabytes in size.
2. Install Vista on the new partition. Pop in the Vista CD and point it to your newly-created partition as the installation destination. Installation will restart your machine at various points.
3. Choose your operating system on boot. Once Vista is installed on your newly-created partition, on boot up, you'll get a choice to start XP or Vista. The default is Vista. However, this can be changed using Vista's boot manager.
When you're up and running with Windows Vista, be sure to check our our Vista upgrade power tips.
The original article appears below for posterity, and it's still got relevant screenshots and other info for those of you looking to dual-boot XP and Vista.
http://www.youtube.com/watch?v=nNZi5fLpqus
(WATCH THE ABOVE VIDEO FOR MORE HELP)
Cheers :-)
Jun 05, 2008 | Dell Latitude D600 Notebook
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
108 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
