Question about Garden
The model WB36K13 Encore walk behind with the 13HP Kawasaki has the oil plug located in a place that makes it hard to drain the oil into a pan without making a mess. If there a special funnel or tool needed?
  • 855 Answers
Depending on the engine ( and most are covered ) , you can go to your local lawn mower shop and purchase a new drain plug. On the new plug it will have a nipple sticking out of it so you can attach a small hose and open a valve to drain the oil into a pan/bottle or whatever you use. These work very well the draw back is putting it in the first time without making a mess.
Posted on Jul 15, 2010
2003 Kawasaki KX 125 how to rethread the oil pan drain hole
Hi, Anonymous for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Striped oil drain plug hole
Cheap Stripped Oil Drain Plug Thread Fix
Stripped Oil Drain Bolt
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
OEM Parts for Kawasaki
2003 Kawasaki KX125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 08, 2013 | 2003 kawasaki KX 125
Where is transmission filter located in 2001 mitsubishi diamante located and how do i change it?
transmission filter in the bottom of transmission bolted to valve body.you need a large drain pan.place drain plug under transmission oil pan.remove transmission oil pan drain plug.let all transmission fluid drain out then screw back drain plug in oil pan.then you need to remove transmission oil pan then remove filter and replace pan gasket also.make sure you have right amount transmission fluid on hand.buy extra because if you short of fluid you cant drive car if fluid level too low.make sure you get the right amount fluid.torque pan bolts to 96 inch pounds.
Nov 10, 2011 | 2001 Mitsubishi Diamante
I am changing the oil my self and want to know which screw to unscrew under the car. i need a diagram to release the the oil from the bottom. where do i find one?
2006 uplander, there maybe a cover to remove to get to the oil pan, lets see if i can find a picture of the drain plug.okay im not sure the engine size in this uplander but they all should be about the same, here are some diagrams to help you locate the oil filter and oil pan drain plug. the oil filter is located from under the engine on the driverside behind the ac compressor, the oil drain plug is located on the bottom of the oil pan on the pass/side. heres a diagram of the two . hope this helps.johnjohn2_90.gifjohnjohn2_91.gifjohnjohn2_92.gif
Mar 20, 2011 | 2006 Chevrolet Uplander
How to change oil pan
if the owner is the one going to change the oil pan , then the owner should locate the oil pan .Prepare the the equipment going to be used in changing the oil pan. First drain the oil or the engine oil that is in the oil pan. In draining, the owner of the car should twist the drain plug until it loose that the oil will spill on a can or to where the owner will place the engine oil.The oil pan is connected to the engine with the bolts . The owner have to twist the bolts until the oil pan is being place out of the engine . then replace the oil pan .Then the owner have to place back the bolt using the bolts to connect the oil pan to the engine twist the bolts again until the new oil pan is connected to the engine.Close or twist the drain plug until engine oil will not spill , Then refill or place engine oil to the engine. If the owner cannot do it then the owner have to go to a car mechanic to do the task or the job.
Sep 26, 2009 | 1996 Plymouth Breeze
HELP, 2007 Toro walk behind mower
There is a drain plug on the block of the motor usually it looks square. if its not behind the blade on the under carriage, then it will be on top above the blades were the motor is visible. you may have to tip the mower on its side to completely drain all the oil. but the plug is always going to be on the motor either on the side or on the bottom. if the plug is on the bottom were the blade is remove the spark plug wire first. a mower can start if you turn the blade by hand and that would be vary bad news so always take the spark plug wire off and make sure it can not come in contact with the spark plug before going underneath the mower.
Jul 30, 2009 | Garden
How to replace transmission oil
to replace the oil on your transmission is not that hard but as a auto technician I should advice you that if on any vehicle the transmission oil has never been changed and is a high millage vehicle by changing the oil the transmission can slip or go neutral you should take your vehicle to a transmission shop and have the oil changed there with special oil changing machine that would clean the transmission and converter while it replaces the old oil and if there's a risk on damaging the transmission then they will tell you before changing the oil on your transmission and if they change the oil and any problems should happen then they are responsible for your transmission but if you insist to change it your self by removing the oil pan on the transmission you let all the oil out some of these Japanese vehicles have a drain plug you can take the brain plug out then remove the oil pan once you remove the oil pan then you'll see the transmission filter with socket wrench using a 10 mm socket remove the filter and the same way replace it with the new filter don't over tork the screws tighten to 15 lb. then remove the old oil pan gasket and make sure by doing all this process everything is extra clean, clean out oil pan and replace gasket and install oil pan then after you finish pour in 3 qt. of good quality transmission oil then turn on engine and take the shifter to R then D and last N and with engine on check the level and add as needed good luck
Jul 17, 2009 | 1997 Isuzu Rodeo
Can't locate reserve oil drain plug on 1994 Ford E350
It only has 1 oil pan which is call a dual resreve. One oil plug is a the bottom of the pan the other is at the front of the oil pan. Look at the front of the oil pan for the other drain plug. Make sure on how many quarts of oil it takes. ( I know 5.0 take 5 quarts including oil filter. But then again its a van double check)
Mar 22, 2009 | 2002 Ford E350
Looking for the Oil Plug (Draining) for a GMC 2001 1500 Silverado
the pan under the motor is the oil pan. you can see the oil filter to the left of it (driverside). The plug is in the rear of it facing the back of the truck. On my 6.0l V8 the exuast pipe is rite behind it so when you loosen it have the drip pan ready to catch the oil as it will stream out fast at a wierd angle due to its location. The pan behind it is for the transmission.
Nov 21, 2008 | 2000 Chevrolet Silverado 1500
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
