Question about Versace 27473-008-00 Wrist Watch
Versace xlc 99 strap the watch is stainless steel. i need a new strap
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
SOURCE: I'm looking for a replacement
You can try calling Casio derectly 1-800-836-8580 If that doesn't work your out of luck unless someone has one they don't need. What is wrong with the one you have? sometimes the band can be repaired. Also some watch people or jewelers who can take a band alot like yours and cut it to fit the watch. Let me know what happens, maybe I can help you.
Posted on Apr 23, 2008
escapement
  • 2338 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
escapement
  • 2338 Answers
SOURCE: trying to shorten stainless steel watch strap
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 27, 2009
dmbgo
  • 58 Answers
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
Posted on Jun 22, 2009
Where to get a new. Watch strap
You can get Watch strap and everything of watch from The Prime Luxury Boutique. It is an authorized luxury watch retailer. http://theprimewatches.com/
Aug 09, 2014 | Rado Diastar Anatom Jubile watch
Dz4107
Some sprint bars need to be curved, get them in stainless steel.
You need to know the MM size of the spring bar, yu may find that on the strap if its the original strap.
Search for - SWISS REIMAGINED Curved Stainless Steel Spring Bar Pins.
For a box of mixed size straight spring bars look for - Ritche Professional 360pc Watch Band Stainless Steel Link Pins.
Pick up the spring bar tool as well. Amazon sells all of it.
Feb 10, 2018 | Diesel DZ4107 Watch for Men
Ebel 1911 stainless steel 18 k bezel strap broken, battery needs replaceing
Any jewelry store can replace the battery.
They can also sell you a new strap.
Anything else wrong with the watch??
Aug 29, 2011 | Watches
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Need links for versace cornishe all stainless model
an authorized retailer will be able to order them for you. Look up the nearest one on the website. http://www.vertime.com
Nov 20, 2006 | Versace Corniche Collection Watch
Versace 27473-008-00 Wrist Watch Logo
199 people viewed this question
Top Versace Watches Experts
john h
ray gallant
TIC TOCK SERVICE
TIC TOCK SERVICE
Are you a Versace Watch Expert? Answer questions, earn points and help others
