Question about Air-O-Swiss 7133 Humidifier
After I cleaned my air-o-swiss humidifier it no longer works. I plug it in and no power seems to be going to the unit.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I have air-o-swiss humidifier. Recently I cleaned it. Its motor appears to be working after that but the mist is not coming out. Any clues?
When you cleaned it , did you remove water level sensor? If so did you put it back in upside down? The sensor is a plastic cylinder that is held down by a screw and washer.. If you have it in upside down, the empty water red light will be lit,,, if you unscrew the sensor and flip it .. it should start to work again..
Dec 05, 2009 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Airo swiss #7133
you do not clean it should have pad in it. replace pad and you should be fine
Feb 03, 2009 | Air-O-Swiss 7133 Humidifier
Air o swiss 7135 turns on but no mist comes out...
would you describe your problem in a little more detail please?
Jan 17, 2009 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Air-o-swiss 7142 humidifier
I just cleaned mine for the first time, and the instructions are very unclear in the pamphlet on how to do it.
What you need:
One package of EZ Cal cleaner/descaler for humidifiers ( I got mine at bed bath and beyond)
32 oz of hot water
How to clean your unit:
Mix the hot water with the EZ Cal cleaner packet in a separate container.
Remove the tank from the base.
Remove the cleaning brush and the silver stick that is in the base of the unit.
Pour the solution in the base of the unit.
Let the solution sit in the base of the unit for 1/2 hour.
Then take the cleaning brush, and go over the surfaces in the base.
Pour out the solution, and rinse with hot water.
Put the brush and silver stick back into the base.
Put tank back onto the base.
Reset the unit by pushing and holding the power button for a few seconds.
This will stop the cleaning indicator from blinking.
Let the water fill up the filter for a couple minutes, turn on, and your ready to go again.
I hope this was helpful.
Nov 03, 2008 | Air-O-Swiss U7142 Humidifier
How to clean air o swiss humidifier
Any bathtub cleaner will work so much as you do a good job cleaning then rinsing. Be careful not to get the humidifier wet anywhere other than the basin that the water goes through.
Jun 17, 2008 | Air-O-Swiss U7142 Humidifier
Red droplet light stays on
I had the same problem. I replaced the filter and cleaned the base and then it worked.
Jan 10, 2008 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Air o swiss 7135
sounds like the filter is not allowing air flow.
Nov 26, 2007 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
After you've cleaned it you can reset it by holding down the ON/OFF button for a few seconds.
Oct 25, 2006 | Air-O-Swiss 7133 Humidifier
Air-O-Swiss 7133 Humidifier Logo
119 people viewed this question
Top Air-O-Swiss Humidifiers Experts
Tom Chichester
Are you an Air-O-Swiss Humidifier Expert? Answer questions, earn points and help others
