Question about Akai 20" TV
Using Component Cables
I have a vcr/dvd combo hooked up to the tv with red,green and blue cables. During the program that I am watching, the tv goes black. You can still hear the voices in the background but there is absolutely no picture. Any help would be greatly appreciated.
  • topsyturvy55 Jul 15, 2010
    I have tried using the red white and yellow wires also. The tv goes black using the above. I have checked several times to make sure the wires were securely in place. If anybody else has any other solutions I would appreciate it.
  • 4,806 Answers
Which input source are the cables connected to AV/Side AV or ypbpr?
Can you describe to me where they are connected and how new is the TV?
Does it support HDMI and have a ypbpr input?
Regards.
Posted on Jul 15, 2010
    The tv is not high definition. They are connected to the YPBR inputs. Can't connect to the AV inputs, have other devices on them.
  • Lee Hodgson
    Lee Hodgson Jul 15, 2010
    We need to check that the VCR/DVD is not the problem here.
    Just for now disconnect the AV input leads from the other device, disconnect the ypbpr leads and connect the red, white and yellow jacks to the AV port.
    Try and watch TV through that source and see if the screen goes black.
    If it doesn't connect the other device to the ypbpr input, turn that device on and see if that goes black.
    If you still get same problems then there could be a fault on the ypbpr leads.
    Let me know how you get on and good luck.
  • Akai Master
  • 6,993 Answers
the red, green and blue cable connection is called component. The three wires are video. They are responsible for display only.
So check these wires, maybe they are not firmly hooked to the unit or might be shaking or the cable might be bad.
Also. you have an option of using a RCA wire connection which is yellow, white and red. In this case, the yellow alone stands for video display, while the white and red is sound audio, unlike the red, green and blue that stands for video alone.
Take care.
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
What cables go from my 55 inch hitachi tv to connect on the back of the dvd player . I have two monster cables red and blue together and three cables red blue and green together.
I have never herd of a red and blue combo but, The three, red, blue, and green are "component" cables. Hopefully your DVD player has a red, blue, adn green component out, not to be confused with red composite out. Composite cables are yellow, red and white, and, your tv has componenet in. The component cable will give you the best video quality. When installing make sure they are inserted all the way but twisting and wiggling or you will have a bluish, grenish, etc. picture. The composite cables give you the video only, so you will have to provide the audio. Audio can be achived using composite red and white or digital optical.If you second monster cable is red and white you can probably use those To go from "audio" red and white out on DVD to audio in red and white on tv. You must use the same audio input that corresponds to you video input.
Apr 09, 2011 | LG BD550 Blu-Ray Player
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
Have sound,no picture
Do you have it hooked up using the component cables?(red, blue, green cables?) You need to use the component cables to use the progressive scan feature. So if you have it hooked up using the yellow rca jack, you will have to switch cables.
May 30, 2008 | GoVideo Go Video DVD/VCR Combo
Akai 20" TV Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
