Question about Nokia 5310 Cellular Phone
My phone keeps saying sim card registration fail and i don't know what to do
  • 524 Answers
Hi...
I belive you got a new sim card.sim card registrations fails comes only when the delear from whom you purchased might havent gave your proff to the service providers. so please contact the delear from whom you got the sim card.
thanx
Posted on Jul 15, 2010
    New Friend:
My sim registration failed to
Posted on Jun 08, 2013
SOURCE: SIM card registration failed
i have the sme problem
Posted on Oct 06, 2008
  • 83 Answers
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
Posted on Jun 10, 2009
ashraf achu
  • 274 Answers
SOURCE: keeps saying sim card registration failed and I got a new
just format your phone
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up
Posted on May 12, 2010
  • 65 Answers
SOURCE: My SIM card is active in other phones but when i
You need to buy an unlock code for the carrier the phone is locked on. eBay is usually a good place to start looking, and these codes are relatively inexpensive
Posted on Apr 03, 2009
  • 1456 Answers
SOURCE: Nokia 6500 slide sim card registration problemit
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
Posted on Jul 27, 2010
Phone says sim card registration has failed
When the message sim card registration failed comes up it is usually as a result of one of 2 things the first being that the phone has not recognized the sim card due to an improper fixing or the sim card has become faulty. Simply try the sim on a different mobile device to determine if the sim card is still good.
Thank you for visiting FixYa.
Hope this solution has been helpful?
Jul 10, 2011 | Nokia N73 Cellular Phone
Keeps saying sim card registration failed and I got a new replacement sim card
May 12, 2010 | Nokia 6210 Navigator Cell Phone
Nokia 5800 locked to orange unlock code,it keeps saying sim registration failed,locked and iv tried 3 different orange sim cards
If it showing you that sim card registration failed then then make sure your sim card is work or not. if your same Sim card works in different phone. it could be that your phone has been blocked by the network
Nov 17, 2009 | Nokia 5800 XpressMusic Smartphone
Simcard registration failed
this may happen when you are using an expired sim card or may be due to electronic data loss from the sim card.try to call the respective customer care from other phone and explain them with your problem,they can help you better
Sep 13, 2009 | Cell Phones
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
The phone keeps displaying sim card registration failed on phone
you have to enter some code after u enter the sim
check out this link
http://www.gsmliberty.net/shop/nokia_unlock.php
i dont assure you but i think it will help you.
thanks.
Oct 01, 2008 | Nokia 6133 Cellular Phone
The sim card holder is too loose on a lot of new Nokia phones. Place some folded paper (3,4,5,6 times) between the sim card and the sim card holder. It should fix it. I have an E65 and had this problems for two days after buying it. Since I fixed it 3 months ago, never had this problem again. Hope it works for you too.
Jul 16, 2008 | Nokia 6300 Cellular Phone
Will not accept my sim ?
You should contact your mobile operator to get a new sim card.
May 09, 2008 | Nokia 7373 Cellular Phone
Feb 25, 2008 | Cell Phones
Nokia 5310 Cellular Phone Logo
1,527 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
