Question about Coleman Proforce 6 Gallon Air Compressor
My Proforce VPP200604 won't turn on. When I plug it in, it hums, but motor doesn't turn on. the motor will spin easily when I turn the fan.
  • mowenc Jul 16, 2010
    Thanks for your help. There is no pressure in the tank so it sounds like a starting capacitor.
  • 553 Answers
I need to amend my last statement. Your problem is probably a burned out starting capacitor but it could also be a nonfunctional presure release valve. If your compressor start when there is no pressure but has these symptoms when there is pressure then the problem is the pressure relief valve rather than the starting capacitor.
Posted on Jul 15, 2010
  • jonesspammai Jul 19, 2010
    Your welcome, sorry for the slow response I don't seem to be getting my notices when I get comments.
Blower won't run
usually a "humming motor" indicates either a bad capacitor or a defective motor. With the power off try to spin the blower wheel...it should spin freely. If it is tight or wont spin and there are no obstructions stopping it (like an air filter sucked into blower or other debris) then the motor most likely is seized. If the blower wheel spins free then you may have a bad capacitor. Keep in mind, just because the blower spins easy doesn't mean the motor is good. I have had motors that are defective that dont seize up but most of the time the blower wheel will not spin free if the motor fails.
Oct 07, 2012 | Desa International Blower Glow Warm Wall...
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
Fan motor hums will not turn.
couple things perhaps.. Bad contactor of bad motor.. sounds like a bad motor though. trun off the unit and see if you can spin the fan easily . that should tell you something. i should spin freely . But that does not mean its not bad it just means that it free.
Jul 15, 2011 | Coleman Heating & Cooling
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
When I turn on the unit, it humms and the fan doesn't turn. Help.
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
Nov 19, 2010 | Bemis 697 400 Humidifier
Hums but wont fire
Remove the top cover, plu it back in and see if the hum goes away, if it
doesn`t look to see if the fan is stuck, if it is unplug and try to spin it
by hand, if it wont spin replace the fan motor
Feb 12, 2010 | Reddy Heating & Cooling
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Nov 18, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Coleman Proforce 6 Gallon Air Compressor Logo
125 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
