Question about Kenmore 98702 Stacked Washer/Dryer
What would cause a washer not to fill? - Kenmore 98702 Stacked Washer/Dryer
  • Kenmore Master
  • 2,699 Answers
A bad water valve.take off the two water lines,stick them in the washer where the clothes go and open the water valve,hold the hoses when you do this,see if any water is coming out the hoses,if not you have a bad house water valve and the washer is ok.if water comes out then you need to check the water valve on the back of the washer.if you need more help you need to send the model number,hope this helps you.
Posted on Jul 16, 2010
  • Sal De Jul 16, 2010
    also could have a bad water level switch,need the model number
Washer fills up with water when off
This is commonly caused by the washer lid switch being defective, unless the washer senses the like switch is closed the washer will not start only fill with water and the nothing.
Jun 30, 2017 | Washing Machines
CROSLEY WASHER CAW9244XQ2 NO FILL
Hello Greg Aguilar - Are the house valves turn on fully? Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Since you have just recently purchased the washer, I strongly suggestion contacting the manufacturer for a listing of certified techs that can move forward accurately.
Dec 09, 2012 | GE WBSR3140DW Top Load Washer
Water not filling up kenmore washer model number11024642300
The most common thing that causes the washer not to fill up with water is the water inlet valve. If this valve has power to it when it's supposed to be filling with water, and you have adequate water supply to the washer, then the washer should be filling with water. The part number for the replacement valve is 285805.
Mar 22, 2012 | Kenmore Washing Machines
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
Not enough water is dispensed during fill cycle. This causes top washer not to have enough water volume to move top washer wand.
First check that the fill float switch is working.
Next that the fill valve doesn't have crud that limits water flow. They MAY have a timeout to prevent overfilling if fill is too slow and that could cause the priblem if fill valve is partially blocked.
Aug 10, 2009 | Kenmore Dishwashers
WASHER WILL NOT STOP FILLING UP WITH WATER
Sounds like the pressure switch is stuck or the fill valve is stuck. If the pressure switch is not satisfied of the water level, it won't agitate, this is most likely cause. If it DOES agitate, then the fill valve is stuck. A kink in the pressure switch line or a pinhole can also cause this problem. The pressure switch is located in the console, it's white with a little clear hose going to it. It connects to the tub close to the bottom.
Mar 25, 2009 | Whirlpool 3.2 cu. ft. Washer
Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
