Question about Canon PowerShot A510 Digital Camera
Power?? My camera turns on and the lens part extends out, but the screen is totally blank. When I switch it to view previous photos, it works fine..I just have to turn it "off" and the pictures come up..But if I switch it to take a picture, it goes completely dark again...it's almost three years old and has no damage done to it...
  • 2 more comments
  • Anonymous Dec 17, 2008
  • Anonymous Dec 21, 2008
    my camera tells me to change batterys when i try to take a foto.
    I can lock at previus taken fotos but when i try to take a new foto the display is black and the lins donĀ“t mov. The batterys are new.
  • Anonymous Apr 19, 2009
    I have the same problem. My A510 quit taking pictures suddenly. I'd put new batteries in it and immediatley it would say "Change the batteries."
    The lens was stuck as well.
    I purchased a new Canon SX110 IS......while I'm waiting for it to come in the mailI I'm charging batteries....just for randomness I put the rechargeables in the A510...it powers up, takes pictures, everythings great....except that I just spent $248 for an SX110 kit!!!
  • mtlmama May 05, 2009
    i have a 2005 canon powershot a510. the camera turns on and i can see the display settings on the screen, but the screen is black with no images...i can press the button to take the photo looking through the viewfinder but when i review it in playback mode it's a black screen, tho i can view the photos taken the day before the black screen problem happened. i just put in freshly charged batteries (properly, i checked several times!) and have an almost full sd card in it. is this fixable or do i need to buy a new camera?
Had the same issue. I changed battery, I replaced Duracell by Sony rechargeable batteries. It works fine now. i think that the issue comes from battery shape. They do not have exactly the same. hope it helps.
Posted on May 04, 2008
My computer will not take my pics off anymore
Posted on Apr 29, 2008
The LCD viewing screen is blank and the camera will no longer take photos. It is still possible to view photos that had previously been taken.
u r not able to operate the camera,not able to get the image,so it is the lens,shutter problem,so take to camera tec.
Mar 08, 2010 | Canon PowerShot A95 Digital Camera
When i turn my camera on, its a blank screen with
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
When FinePix V10 digital camera is switched on the LCD screen is blank, The lens works but does not display picture. FujiFilm Digital Camera FinePix V10
Hi, When you say the screen is "blank" Is it totally blank or do the icons appear on screen? can you review any previous pictures etc?
As the camera still powers up it is possible that the ribbon for the screen has popped out of it's socket.
My email is listed in "the only way i know how.." In my tips n tricks section on my profile if you would like more advice.
Aug 15, 2009 | Fuji Cameras
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
The lens will not retract. When in picture mode er18 appears on the otherwise blank screen. It will switch to allow me to view the pictures on the card
Oct 10, 2008 | Cameras
Problem with camara
Lens isn't working and need to be replaced.
Jun 07, 2008 | Cameras
Access Message
This is a hardware problem. Your simptons is tipical of a lens position sensor being faulty.
There is however nothing you can do yourself. Contact your nearest Sony dealer and take the camera to a Sony service centre.
They will quote you for a new lens assembly as they will not be able to replace the sensor only.
Cost should be about 1/2 of what you paid for the camera.
Good luck.
Feb 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Canon PowerShot A510 Digital Camera Logo
155 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
