Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
The centre ring on my lens has fallen into the inside of the lens. what can i do to fix this?
  • sue_zapf Jul 15, 2010
    Thank you so much!!
  • 3,083 Answers
You're going to have to disassemble the lens and reseat the ring. This is never easy, since there is a precise way all the lenses and focusing mechanisms have to be reseated exactly right, and there is the issue of dirt or dust getting into the lens when you attempt to disassemble it and try to fix it. I wouldn't think the average person could successfully repair this lens, but a skillful technician of sorts may be able to. It's going to be hard to find a technical procedure for this, since only repair facilities usually do this. My suggestion would be to take it in to a reputable repair shop and see what they think. Often the cost of labor to repair a simple thing like this can exceed replacement cost, so make sure you get an estimate before considering having it fixed. If the repair shop wants too much, you might opt to try it yourself. Just make sure you have a set of jeweler's screwdrivers, and make a diagram of each screw and location, as you go, and use extreme care not to touch the lens surfaces any more than you have to. You might get lucky and get it working. Good luck, and hope this helps.
Posted on Jul 15, 2010
After dropping my nikon d5000 camera the lense doesn't seem to fit
If you drop one, the main components that can get damaged are the lens elements, the focusing ring, the aperture ring, the lens mount and the filter mount. Some of these components are much easier to fix than others.
usb memory card reader
Mar 12, 2012 | Nikon D5000 Digital Camera
SEL16F28 has dust inside the lens
Almost all lenses get dust inside them. It's rarely bad enough to affect image quality in the slightest so is usually ignored.
The only fix is to pay to have a Sony service centre strip down the lens, clean it, and reassemble it, but it would be far cheaper to sell yours and buy a new example. Either way, unless you never take the lens out of the packaging it will soon get dust inside it again.
Aug 04, 2011 | Sony SEL16F28 16mm f28 Emount WideAngle...
My 400mm lens is so hard to slide out when I go to zoom what do I do
turn the 'lock/friction ring' (metal band just below the black rubber focusing ring) counter clockwise whilst holding the focusing 'ring' still. The friction/lock ring is used to prevent 'lens creep' when carrying the camera with lens pointing down, or using the lens when it is pointing down. Juust turn it until it applies the level of friction you prefer for operating the lens. If you have already tried this and it won't budge it may be the bearings are shot and you will need to contact a canon service centre for repair.
Dec 03, 2010 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
It dropped, we got all the pieces but the lens has two lose springs and the lens protectors won't close or open any more
The lens mountings have come out and hence the shutters have moved out of mechanism and alignment. It will be necessary to open the camera and start to refix them. If it had fallen on the lens then there is a possibility of the the hood mounting been damaged. If so you will need to fix this out but if any plastics are broken then the alignment may not set well . The best is to approach a camera repair centre preferably Canon , and try to piece it , this will be much better than to assume the fittings. Hope you try this out. Good day
Aug 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Miele w865 - door won't open after completed wash cycle
the solenoid sounds like it is defective on the door lock or the plug has fallen out of the door lock. if you remove the sealing ring clip which holds the door seal in place and pull back the seal you can reach inside the unit and make sure the plug is in place. check also there is power to the plug
hope this helps. if all else fails call the Miele service centre in your area and they will be able to help
May 08, 2010 | Miele W865 Front Load Washer
My camera was dropped and now there are two little pieces of the inside of the camera inside my lens and it won't zoom. is there a way i can take it apart to try to fix it?
assembly of the lens unit is disterbed,lens operation isnot possible,inside optic rings may be broken,so replace with anew lens unit
Mar 04, 2010 | Fuji FinePix F650 Digital Camera
Lumix dmlt55 telelens, the ring inside is not fixed
As it arrived in a broken state, return it for a full refund.
Jul 22, 2017 | Panasonic Cameras
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
Loose Focus ring assembly
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Aug 25, 2006 | Sony Handycam DCR-TRV30 Mini DV Digital...
Digital dsc F707 problem
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
48 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
