Question about Hamilton Beach Water Cooler with Storage Cabinet
My water cooler won't cool water. The hot is piping hot and the cold is very warm. have had it for 4 years could it just be old? Should I just replace it?
2 Suggested Answers
  • 3 Answers
SOURCE: My water cooler won't cool
Check to see if fans are working i just bought a used one and one of the fans was not working and i fixed it and sems to be working
Posted on Feb 16, 2012
Kenmore Washer 600 Series SM9711916
Wrong water line. Go a head swap the water line. You should be good to go.
Good luck
Mai
Jul 20, 2018 | Kenmore Washing Machines
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Cooler not running
Check power to relay. If yes, check compressor is working. If yes, keep your hand on discharge pipe. If it's not warm, cooler is under gas leak. Rectify leak and recharge gas.Thanks.
Jan 24, 2011 | Whynter FX-6SB Free Standing Hot & Cold...
My water cooler won't cool water. The hot is piping hot and the cold is very warm. what should i do?
Nov 07, 2010 | Hamilton Beach Water Cooler with Storage...
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
Heater not working
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Home
Hamilton Beach Water Cooler with Storage Cabinet Logo
509 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
John Tripp
John Tripp
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
